Hi!, I am trying to setup a proxy server in order to access (more) easily my services in my home network.
For example, when I am abroad I would like to type on a browser
https xxx.duckdns.org :8123 and go to my Home Assistant website 192 .168.1.12:8123
https xxx.duckdns.org :5050 and go to my Hadashboard website 192 .168.1.12:5050
https xxx.duckdns.org :8080 and go to my Qnap 192.168.1.21:8080
and other services.
Is this possible? If yes, how?
Hi @claudioita , welcome to the Caddy community. It absolutely is possible. Assuming you have:
xxx.duckdns.org pointed at your public IP address
Ports 80, 443, 8123, 5050, and 8080 forwarded to your Caddy host
You’ll want to use site labels exactly as you’ve typed - e.g. https://xxx.duckdns.org:8123. One site definition block for each port/proxy.
The proxy is pretty straightforward, too, just proxy everything to the back end as you’ve typed it, e.g. 192.168.1.12:8123.
https://caddyserver.com/docs/proxy
If you have any issues, let us know what your current Caddyfile is, and what you’ve already tried, and we can help you get it going.
Thats my caddyfile I would like to use (as new user in this forum I can’t put more then 4 links … wtf …?). Is the below ok (please note first adddress without port)?
https://xxx.duckdns.org {
tls /ssl/fullchain.pem /ssl/privkey.pem {
alpn http/1.1
proxy / 192.168.1.12:8123 {
websocket
log stdout
errors stderr
https://xxx.duckdns.org:8080 {
alpn http/1.1
proxy / 192.168.1.21:8080 {
websocket
log stdout
errors stderr
https://xxx.duckdns.org:5050 {
alpn http/1.1
proxy / 192.168.1.12:5050 {
websocket
log stdout
errors stderr
Whitestrake:
I see, before I forwarded only 80 and 443. One of the reason I wanted a proxy server is to not open too many ports … I guess I have no other choice …
pwhodges
(Paul Hodges)
March 5, 2018, 11:36am
5
Surely you could use the same port and subdirectories instead of messing around with more ports:
https://xxx.duckdns.org/site1
https://xxx.duckdns.org/site2
https://xxx.duckdns.org/site3
and proxy each of them based on that:
proxy /site1 192.168.1.12:8123 {
without /site1
proxy /site2 192.168.1.12:5050 {
without /site2
proxy /site3 192.168.1.21:8080 {
without /site3
You may need to use the filter plugin to put the /site# back on any returned URLs.
