Caddy as reverse proxy for multiple node-red instances
caddy running on Ubuntu 20.04 with systemd
sudo systemctl start caddy
paste full file contents here
    auto_https off
http://nzb.luytsm.be {
    reverse_proxy 192.168.0.25:6789
http://ha.luytsm.be {
    reverse_proxy 192.168.0.25:8123
http://home.luytsm.be {
    reverse_proxy 192.168.0.25:22
http://plex.luytsm.be {
    reverse_proxy 192.168.0.25:32400
http://nr.luytsm.be {
    reverse_proxy 192.168.0.25:1880
http://iote-one.luytsm.be/ {
    reverse_proxy 192.168.0.25:8881 {
http://iote-two.luytsm.be/ {
    reverse_proxy 192.168.0.25:8882
http://iote-three.luytsm.be/ {
    reverse_proxy 192.168.0.25:8883
http://iote-four.luytsm.be/ {
    reverse_proxy 192.168.0.25:8884
http://iote-five.luytsm.be/ {
    reverse_proxy 192.168.0.25:8885
http://iote-six.luytsm.be/ {
    reverse_proxy 192.168.0.25:8886
http://iote-seven.luytsm.be/ {
    reverse_proxy 192.168.0.25:8887
http://iote-eight.luytsm.be/ {
    reverse_proxy 192.168.0.25:8888
I am running 8 Node Red instances as an container with docker. I am trying to expose the docker containers to the internet. When I try to access the containers from their URL as described in the Caddyfile the pages wont load completely. I receive a blank page in my browser. But I can see the neccesary files when inspecting the webpage. When I navigate to Node Red containers with their IP and port they load completely .
I receive the following data when inspecting the
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0"/>
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="mobile-web-app-capable" content="yes">
  Copyright JS Foundation and other contributors, http://js.foundation
  Licensed under the Apache License, Version 2.0 (the "License");
  you may not use this file except in compliance with the License.
  You may obtain a copy of the License at
  http://www.apache.org/licenses/LICENSE-2.0
  Unless required by applicable law or agreed to in writing, software
  distributed under the License is distributed on an "AS IS" BASIS,
  WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
  See the License for the specific language governing permissions and
  limitations under the License.
<title>Node-RED</title>
<link rel="icon" type="image/png" href="favicon.ico">
<link rel="mask-icon" href="red&#x2F;images&#x2F;node-red-icon-black.svg" color="#8f0000">
<link rel="stylesheet" href="vendor/jquery/css/base/jquery-ui.min.css">
<link rel="stylesheet" href="vendor/font-awesome/css/font-awesome.min.css">
<link rel="stylesheet" href="red/style.min.css">
</head>
<body spellcheck="false">
<div id="red-ui-editor"></div>
<script src="vendor/vendor.js"></script>
<script src="red&#x2F;red.min.js"></script>
<script src="red&#x2F;main.min.js"></script>
</body>
</html>
I am able to run one node red instance with default port and a reverse proxy.
I think a solution would be to alter the used port of all the node red instances but this option is not scalable.
I want to be able to quickly destroy and create instances because this will be used by students in my class
a. Dockerfile
FROM nodered/node-red
RUN npm install node-red-dashboard node-red-contrib-ring-buffer
COPY settings.js /data/settings.js
COPY flows.json /data/flows.json
b. docker-compose.yml
version: "3.2"
  node-red:
    build: .
docker-compose up --scale node-red=8 -d
This is because you have trailing / in your site addresses. This gets handled as a path matcher. In Caddy v2, path matching is exact, so this means that it will only match on exactly / and not /foo. So just remove the trailing slash from all of your site blocks.
In other words, change http://iote-one.luytsm.be/ to http://iote-one.luytsm.be
