Caddy as reverse proxy for git to github.com
Given a network constraint, I need to use git through a proxy.
The proxy is Caddy and the team allowed to configure it for me, I gave a configuration to use, but it seems it’s not working, looks like the communication can’t get back to the client.
Seems no error are shown on the caddy side. I did add the debug option but there is no line involving the endpoint of interest.
lucaslorentz/caddy-docker-proxy:2.8.10
Docker
Relevant part I provided under handle_path /github/*
api.<redacted>.it {
	handle_path /github/* {
		reverse_proxy https://github.com {
			header_up Host {upstream_hostport} <-- seemed relevant to allow Github to recognize the original request
	reverse_proxy <redacted>:3001
git has been configured to use the proxy by issuing the commands below in the repo:
git config http.proxy <redacted>:80/github, same for https 443.
I had to specify the ports otherwise git attempted a connection to port 1080 (socks?)
which results to the block in .git\config
[http]
	proxy = http://api.<redacted>.it:80/github/
[https]
	proxy = https://api.<redacted>.it:443/github/
GIT LOGS
C:\Users\federicod\Downloads\test-proxy>set GIT_CURL_VERBOSE=1
C:\Users\federicod\Downloads\test-proxy>git fetch
22:11:16.915353 http.c:937              == Info: Host <redacted>:80 was resolved.
22:11:16.916341 http.c:937              == Info: IPv6: (none)
22:11:16.917355 http.c:937              == Info: IPv4: <redacted>
22:11:16.919855 http.c:937              == Info:   Trying <redacted>:80...
22:11:16.931407 http.c:937              == Info: CONNECT tunnel: HTTP/1.1 negotiated
22:11:16.931407 http.c:937              == Info: allocate connect buffer
22:11:16.931407 http.c:937              == Info: Establish HTTP proxy tunnel to github.com:443
22:11:16.932378 http.c:884              => Send header, 0000000121 bytes (0x00000079)
22:11:16.933405 http.c:896              => Send header: CONNECT github.com:443 HTTP/1.1
22:11:16.933405 http.c:896              => Send header: Host: github.com:443
22:11:16.934384 http.c:896              => Send header: User-Agent: git/2.46.1.windows.1
22:11:16.934384 http.c:896              => Send header: Proxy-Connection: Keep-Alive
22:11:16.942400 http.c:884              <= Recv header, 0000000033 bytes (0x00000021)
22:11:16.943379 http.c:896              <= Recv header: HTTP/1.1 308 Permanent Redirect
22:11:16.943379 http.c:884              <= Recv header, 0000000019 bytes (0x00000013)
22:11:16.945772 http.c:896              <= Recv header: Connection: close
22:11:16.946815 http.c:884              <= Recv header, 0000000031 bytes (0x0000001f)
22:11:16.947791 http.c:896              <= Recv header: Location: https://github.com/
22:11:16.947791 http.c:884              <= Recv header, 0000000015 bytes (0x0000000f)
22:11:16.948813 http.c:896              <= Recv header: Server: Caddy
22:11:16.948813 http.c:884              <= Recv header, 0000000037 bytes (0x00000025)
22:11:16.948813 http.c:896              <= Recv header: Date: Wed, 23 Oct 2024 20:11:16 GMT
22:11:16.949798 http.c:884              <= Recv header, 0000000019 bytes (0x00000013)
22:11:16.949798 http.c:896              <= Recv header: Content-Length: 0
22:11:16.949798 http.c:884              <= Recv header, 0000000002 bytes (0x00000002)
22:11:16.950796 http.c:896              <= Recv header:
22:11:16.950796 http.c:937              == Info: CONNECT tunnel failed, response 308
22:11:16.950796 http.c:937              == Info: closing connection #0
fatal: unable to access 'https://github.com/maxiride/upptime.git/': CONNECT tunnel failed, response 308
From my understanding, git did attempt the connection through the proxy, successfully resolved the address and subsequent connection to github but couldn’t complete the round trip I guess.
The 308 error code made me think I provided a wrong configuration, I also did try to reverse proxy to http://github.com with the same results.
You’re looking for a forward proxy, not a reverse proxy. See GitHub - caddyserver/forwardproxy: Forward proxy plugin for the Caddy web server
Thanks for the link, I guess the difference between a forward and a reverse isn’t that clear for me.
It’s my understanding that a forward proxy would forward to any address but only GitHub needs to be reachable and only from request coming from the designated server, is that something a forward proxy can achieve? Or do I need to mix/match basic Caddy configurations with the plugin configuration?
Ah, in that case reverse_proxy can work, but you’ll always have trouble reverse proxying to a server not under your control because you’re at the whims of that server.
In particular, using a subpath brings complications. See this article:
You might be able to do it using a subdomain instead of a subpath, but :man_shrugging:
