I have setup the checkmk using docker and installed the caddy on ubuntu server without using docker, I mean directly on the native linux, I just have configured the Caddy file to include reverse proxy for checkmk but I can see caddy service is not active please suggest if there is any need of change in configuration file. Overall agenda is to run zabbix and checkmk as reverse proxy, if any links or any suggestions will be welcomed how to configure caddy as reverse proxy for monitoring environment
NA
version- v2.7.6
using caddy documentation for ubuntu
Linux Prometheus-Server 5.4.0-125-generic #141-Ubuntu SMP Wed Aug 10 13:42:03 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
Thanks for the reply, Yah I have followed the steps given in the caddy documentation for installation, as per my observation when caddy is installed it was active and running but when configuration in caddy file was altered with the inclusion of checkmk configuration in the caddy file , then the caddy service was inactive, so as per my analysis the issue being part of caddy file configuration, so it will be great help if there is possible of tuning in any of the configuration file or any suggestion put forwarded. Below is the configuration file for Caddy file.
Note- The caddy is running in bare linux without docker or docker compose, and checkmk is running on docker and binded in port 8080
Thanks in advance
please below configuration of caddy file
# domain name.
root * /usr/share/caddy
# php_fastcgi localhost:9000
:443{
tls /etc/caddy/certificate/cert.pem /etc/caddy/certificate/key.pem
reverse_proxy [http://127.0.0.1:8080](http://127.0.0.1:8080/)
It’s probably inactive because it failed to start due to a syntax error.
Did you check your logs? See the command in the docs I linked.
Delete all this. You’re meant to replace the whole config with your own. That’s just an example to present you with a welcome page, it shouldn’t be left in.
Don’t put :443, you should put your actual domain as the site address.
And you probably don’t already have your own TLS certificate, so don’t use the tls directive. Remove all that.
Now I see Caddy is running, below is the caddy file configuration for it. Here my domain is checkmk.com, here question arises iam accessing the checkmk through http://local host:8080 but when I checked to access through https://local host:8080 iam not able to access the checkmk
Can I replace the domain name with ip and see or any further troubleshooting is necessary in configuration file, it will be great help what steps can be followed further to get it running
After thorough research and revalidation Iam able to run reverse proxy for uptime kuma, which can be accessible over https.
Now Iam trying to include combination of multiple reverse_proxy directives in the same block such as uptime kuma, zabbix and checkmk, will I be able to make and work over https, if it is so requesting to post a valid Caddy configuration file that includes all three uptime, zabbix and checkmk.
