Hello,
I would like to know if it exists a such plugin : listening docker events api and so creating route to access docker containers ?
I would be interested to do it else.
Thanks
Hello,
Thanks
You could create something using docker-gen and caddy graceful restarts.
Thanks for information. I found
https://github.com/BlackGlory/caddy-proxy which use docker-gen
I will try it. Thanks
I’m not sure if this is similar to what you want, but maybe you’d be interested in https://github.com/mholt/caddy/pull/564 ?
I have created a tool called caddy-gen, it is a mix of docker-gen and caddy (with graceful restarts).
Check it out: GitHub - wemake-services/caddy-gen: Automated Caddy reverse proxy for docker containers
