Hi,
at my current job, users often get lost when trying to reach k8s deployments for test systems which have been stopped. By default, the k8s nginx-ingress just returns a meaningless error message when no service behind the ingress is available. By defining a default backend (Annotations - Ingress-Nginx Controller), you can provide hints to the users on how to fix the current error.
(Caveat: This is only tested with the nginx-ingress-controller, other ingress controllers might provide similar features)
Caddyfile
admin off
http://:8080
root * /srv/www
encode zstd gzip
@custom_err header_regexp X-Code ^\d+$
error @custom_err "Default {header.X-Code}" {header.X-Code}
templates
handle_errors {
@custom_accept_json header_regexp Accept \b(application|text)/json\b
respond @custom_accept_json `\{error: {err.status_code}, msg: "Ingress: {err.status_text}"\}`
@err_file file /err-{err.status_code}.html /err.html
handle @err_file {
rewrite * {file_match.relative}
templates
respond "{err.status_code} {err.status_text}"
The deployment is nothing special, but sets two variables for use in the error pages:
env:
- name: RANCHERURL
value: https://k8s-prod.company.internal/dashboard/c/some-cluster-id/explorer
- name: STATICSITE
value: https://default-backend.k8s-prod.company.internal
The webroot contains a bunch of templated HTML files to direct the user to the admin interface, for example:
err.html
<!DOCTYPE html>
<head>
<meta http-equiv="content-type" content="text/html;charset=utf-8">
<link rel="stylesheet" href="{{env "STATICSITE"}}/water-2.1.1.min.css" integrity="sha256-QST90Wzz4PEr5KlclQaOCsjc00FTyf86Wrj41oqZB4w=" crossorigin="anonymous">
<title>Ingress {{placeholder "http.error.status_code"}} - {{placeholder "http.error.status_text"}}</title>
</head>
<body>
<h2>Error {{placeholder "http.error.status_code"}} - {{placeholder "http.error.status_text"}}</h2>
{{include "upstream-error.html"}}
</body>
</html>
err-503.html
<!DOCTYPE html>
<head>
<meta http-equiv="refresh" content="600">
<title>{{.Req.Header.Get "X-Ingress-Name"}} - missing workload error</title>
</head>
<body>
<h2>Sorry Mario, your workload is in another castle.</h2>
<p>It seems the system you want to reach (<code>{{.Host}}</code>) isn't
able to accept your requests right now.</p>
</body>
</html>
upstream-error.html
{{if .Req.Header.Get "X-Ingress-Name"}}
<p>If you are responsible for the system, take a look at Rancher
(<a href="{{env "RANCHERURL"}}/networking.k8s.io.ingress/{{.Req.Header.Get "X-Namespace"}}/{{.Req.Header.Get "X-Ingress-Name"}}">Ingress</a>,
<a href="{{env "RANCHERURL"}}/service/{{.Req.Header.Get "X-Namespace"}}/{{.Req.Header.Get "X-Service-Name"}}">Service</a>)
to find out what the problem is.</p>
{{end}}
By constructing URLs to the Rancher admin interface from the base URL and the “magic” headers the ingress controller uses, we can direct users to the correct please where they can start debugging why the system isn’t reachable.
