I ran journalctl -u caddy --no-pager | less +G
Oct 30 03:46:07 triggr systemd[1]: caddy.service: Deactivated successfully.
Oct 30 03:46:07 triggr systemd[1]: caddy.service: Consumed 5.721s CPU time.
Oct 30 03:51:08 triggr systemd[1]: Starting Caddy...
Oct 30 03:51:08 triggr caddy[2314662]: caddy.HomeDir=/var/lib/caddy
Oct 30 03:51:08 triggr caddy[2314662]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 03:51:08 triggr caddy[2314662]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 03:51:08 triggr caddy[2314662]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 03:51:08 triggr caddy[2314662]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 03:51:08 triggr caddy[2314662]: runtime.GOOS=linux
Oct 30 03:51:08 triggr caddy[2314662]: runtime.GOARCH=amd64
Oct 30 03:51:08 triggr caddy[2314662]: runtime.Compiler=gc
Oct 30 03:51:08 triggr caddy[2314662]: runtime.NumCPU=2
Oct 30 03:51:08 triggr caddy[2314662]: runtime.GOMAXPROCS=2
Oct 30 03:51:08 triggr caddy[2314662]: runtime.Version=go1.21.3
Oct 30 03:51:08 triggr caddy[2314662]: os.Getwd=/
Oct 30 03:51:08 triggr caddy[2314662]: LANG=C.UTF-8
Oct 30 03:51:08 triggr caddy[2314662]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 03:51:08 triggr caddy[2314662]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 03:51:08 triggr caddy[2314662]: HOME=/var/lib/caddy
Oct 30 03:51:08 triggr caddy[2314662]: LOGNAME=caddy
Oct 30 03:51:08 triggr caddy[2314662]: USER=caddy
Oct 30 03:51:08 triggr caddy[2314662]: INVOCATION_ID=834aacf59f7144b0bcf31e4776bdabdd
Oct 30 03:51:08 triggr caddy[2314662]: JOURNAL_STREAM=8:13868227
Oct 30 03:51:08 triggr caddy[2314662]: SYSTEMD_EXEC_PID=2314662
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.580558,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.5843325,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"warn","ts":1698637868.5846622,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.5852318,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.5856423,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000284e80"}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.5859134,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.586025,"msg":"serving initial configuration"}
Oct 30 03:51:08 triggr systemd[1]: Started Caddy.
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.586648,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Oct 30 03:51:08 triggr caddy[2314662]: {"level":"info","ts":1698637868.5896006,"logger":"tls","msg":"finished cleaning storage units"}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2184496,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"43954","headers":{"Accept-Encoding":["gzip"],"Content-Length":["255"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2196274,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2198339,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2198572,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2208517,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2221007,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2224126,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.222428,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["trig.iamobinna.com"]}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.224157,"logger":"http","msg":"servers shutting down with eternal grace period"}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.224571,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2248662,"logger":"admin.api","msg":"load complete"}
Oct 30 03:51:13 triggr caddy[2314662]: {"level":"info","ts":1698637873.2304401,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 30 03:54:07 triggr caddy[2314662]: {"level":"info","ts":1698638047.9424276,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
Oct 30 03:54:07 triggr caddy[2314662]: {"level":"warn","ts":1698638047.9426591,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
Oct 30 03:54:07 triggr caddy[2314662]: {"level":"info","ts":1698638047.9428897,"logger":"http","msg":"servers shutting down with eternal grace period"}
Oct 30 03:54:07 triggr systemd[1]: Stopping Caddy...
Oct 30 03:54:08 triggr caddy[2314662]: {"level":"info","ts":1698638048.2117739,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 30 03:54:08 triggr caddy[2314662]: {"level":"info","ts":1698638048.2118294,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Oct 30 03:54:08 triggr systemd[1]: caddy.service: Deactivated successfully.
Oct 30 03:54:08 triggr systemd[1]: Stopped Caddy.
Oct 30 03:54:20 triggr systemd[1]: Starting Caddy...
Oct 30 03:54:20 triggr caddy[2314802]: caddy.HomeDir=/var/lib/caddy
Oct 30 03:54:20 triggr caddy[2314802]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 03:54:20 triggr caddy[2314802]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 03:54:20 triggr caddy[2314802]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 03:54:20 triggr caddy[2314802]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 03:54:20 triggr caddy[2314802]: runtime.GOOS=linux
Oct 30 03:54:20 triggr caddy[2314802]: runtime.GOARCH=amd64
Oct 30 03:54:20 triggr caddy[2314802]: runtime.Compiler=gc
Oct 30 03:54:20 triggr caddy[2314802]: runtime.NumCPU=2
Oct 30 03:54:20 triggr caddy[2314802]: runtime.GOMAXPROCS=2
Oct 30 03:54:20 triggr caddy[2314802]: runtime.Version=go1.21.3
Oct 30 03:54:20 triggr caddy[2314802]: os.Getwd=/
Oct 30 03:54:20 triggr caddy[2314802]: LANG=C.UTF-8
Oct 30 03:54:20 triggr caddy[2314802]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 03:54:20 triggr caddy[2314802]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 03:54:20 triggr caddy[2314802]: HOME=/var/lib/caddy
Oct 30 03:54:20 triggr caddy[2314802]: LOGNAME=caddy
Oct 30 03:54:20 triggr caddy[2314802]: USER=caddy
Oct 30 03:54:20 triggr caddy[2314802]: INVOCATION_ID=e26423ad3c0d4612bce39d42a0ab20bb
Oct 30 03:54:20 triggr caddy[2314802]: JOURNAL_STREAM=8:13868562
Oct 30 03:54:20 triggr caddy[2314802]: SYSTEMD_EXEC_PID=2314802
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.683224,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6856084,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//127.0.0.1:2019","//localhost:2019","//[::1]:2019"]}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"warn","ts":1698638060.6857765,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6861124,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6864572,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 30 03:54:20 triggr systemd[1]: Started Caddy.
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6876566,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00032c600"}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6879215,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6889293,"msg":"serving initial configuration"}
Oct 30 03:54:20 triggr caddy[2314802]: {"level":"info","ts":1698638060.6892607,"logger":"tls","msg":"finished cleaning storage units"}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2607245,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"46858","headers":{"Accept-Encoding":["gzip"],"Content-Length":["255"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2637255,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2639983,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2640433,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.267145,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2674522,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2677996,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2679553,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["trig.iamobinna.com"]}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2689366,"logger":"http","msg":"servers shutting down with eternal grace period"}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2693546,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2696538,"logger":"admin.api","msg":"load complete"}
Oct 30 03:54:57 triggr caddy[2314802]: {"level":"info","ts":1698638097.2753625,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 30 03:55:37 triggr caddy[2314802]: {"level":"info","ts":1698638137.4475975,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/stop","remote_ip":"127.0.0.1","remote_port":"49016","headers":{"Accept-Encoding":["gzip"],"Content-Length":["0"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Oct 30 03:55:37 triggr caddy[2314802]: {"level":"warn","ts":1698638137.4494092,"logger":"admin.api","msg":"exiting; byeee!! 👋"}
Oct 30 03:55:37 triggr caddy[2314802]: {"level":"info","ts":1698638137.4494433,"logger":"http","msg":"servers shutting down with eternal grace period"}
Oct 30 03:55:37 triggr caddy[2314802]: {"level":"info","ts":1698638137.7232268,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 30 03:55:37 triggr caddy[2314802]: {"level":"info","ts":1698638137.7232914,"logger":"admin.api","msg":"shutdown complete","exit_code":0}
Oct 30 03:55:37 triggr systemd[1]: caddy.service: Deactivated successfully.
Oct 30 03:57:36 triggr systemd[1]: Starting Caddy...
Oct 30 03:57:36 triggr caddy[2315053]: caddy.HomeDir=/var/lib/caddy
Oct 30 03:57:36 triggr caddy[2315053]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 03:57:36 triggr caddy[2315053]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 03:57:36 triggr caddy[2315053]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 03:57:36 triggr caddy[2315053]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 03:57:36 triggr caddy[2315053]: runtime.GOOS=linux
Oct 30 03:57:36 triggr caddy[2315053]: runtime.GOARCH=amd64
Oct 30 03:57:36 triggr caddy[2315053]: runtime.Compiler=gc
Oct 30 03:57:36 triggr caddy[2315053]: runtime.NumCPU=2
Oct 30 03:57:36 triggr caddy[2315053]: runtime.GOMAXPROCS=2
Oct 30 03:57:36 triggr caddy[2315053]: runtime.Version=go1.21.3
Oct 30 03:57:36 triggr caddy[2315053]: os.Getwd=/
Oct 30 03:57:36 triggr caddy[2315053]: LANG=C.UTF-8
Oct 30 03:57:36 triggr caddy[2315053]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 03:57:36 triggr caddy[2315053]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 03:57:36 triggr caddy[2315053]: HOME=/var/lib/caddy
Oct 30 03:57:36 triggr caddy[2315053]: LOGNAME=caddy
Oct 30 03:57:36 triggr caddy[2315053]: USER=caddy
Oct 30 03:57:36 triggr caddy[2315053]: INVOCATION_ID=ec5b5b3e95e443068ca9973061faceac
Oct 30 03:57:36 triggr caddy[2315053]: JOURNAL_STREAM=8:13869161
Oct 30 03:57:36 triggr caddy[2315053]: SYSTEMD_EXEC_PID=2315053
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3402247,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3428435,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"warn","ts":1698638256.3430324,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3433352,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3436043,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.343691,"msg":"serving initial configuration"}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3437688,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/var/lib/caddy/.local/share/caddy"}
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3448524,"logger":"tls","msg":"finished cleaning storage units"}
Oct 30 03:57:36 triggr systemd[1]: Started Caddy.
Oct 30 03:57:36 triggr caddy[2315053]: {"level":"info","ts":1698638256.3435931,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00042fe80"}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.297396,"logger":"admin.api","msg":"received request","method":"POST","host":"localhost:2019","uri":"/load","remote_ip":"127.0.0.1","remote_port":"54226","headers":{"Accept-Encoding":["gzip"],"Content-Length":["255"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.2983317,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.2990599,"logger":"http.auto_https","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.299303,"logger":"http.auto_https","msg":"enabling automatic HTTP->HTTPS redirects","server_name":"srv0"}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3001842,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3005202,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3006008,"logger":"http.log","msg":"server running","name":"remaining_auto_https_redirects","protocols":["h1","h2","h3"]}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.300611,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["trig.iamobinna.com"]}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3016248,"logger":"http","msg":"servers shutting down with eternal grace period"}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3020446,"msg":"autosaved config (load with --resume flag)","file":"/var/lib/caddy/.config/caddy/autosave.json"}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3022802,"logger":"admin.api","msg":"load complete"}
Oct 30 03:57:38 triggr caddy[2315053]: {"level":"info","ts":1698638258.3037343,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 30 03:58:45 triggr systemd[1]: Stopping Caddy...
Oct 30 03:58:45 triggr caddy[2315053]: {"level":"info","ts":1698638325.5693045,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
Oct 30 03:58:45 triggr caddy[2315053]: {"level":"warn","ts":1698638325.5695133,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
Oct 30 03:58:45 triggr caddy[2315053]: {"level":"info","ts":1698638325.56959,"logger":"http","msg":"servers shutting down with eternal grace period"}
Oct 30 03:58:45 triggr caddy[2315053]: {"level":"info","ts":1698638325.5699108,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
Oct 30 03:58:45 triggr caddy[2315053]: {"level":"info","ts":1698638325.5699286,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
Oct 30 03:58:45 triggr systemd[1]: caddy.service: Deactivated successfully.
Oct 30 03:58:45 triggr systemd[1]: Stopped Caddy.
Oct 30 04:26:27 triggr systemd[1]: Starting Caddy...
Oct 30 04:26:27 triggr caddy[2316432]: caddy.HomeDir=/var/lib/caddy
Oct 30 04:26:27 triggr caddy[2316432]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 04:26:27 triggr caddy[2316432]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 04:26:27 triggr caddy[2316432]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 04:26:27 triggr caddy[2316432]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 04:26:27 triggr caddy[2316432]: runtime.GOOS=linux
Oct 30 04:26:27 triggr caddy[2316432]: runtime.GOARCH=amd64
Oct 30 04:26:27 triggr caddy[2316432]: runtime.Compiler=gc
Oct 30 04:26:27 triggr caddy[2316432]: runtime.NumCPU=2
Oct 30 04:26:27 triggr caddy[2316432]: runtime.GOMAXPROCS=2
Oct 30 04:26:27 triggr caddy[2316432]: runtime.Version=go1.21.3
Oct 30 04:26:27 triggr caddy[2316432]: os.Getwd=/
Oct 30 04:26:27 triggr caddy[2316432]: LANG=C.UTF-8
Oct 30 04:26:27 triggr caddy[2316432]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 04:26:27 triggr caddy[2316432]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 04:26:27 triggr caddy[2316432]: HOME=/var/lib/caddy
Oct 30 04:26:27 triggr caddy[2316432]: LOGNAME=caddy
Oct 30 04:26:27 triggr caddy[2316432]: USER=caddy
Oct 30 04:26:27 triggr caddy[2316432]: INVOCATION_ID=459a332383ba4c82a34cdc686f4eee72
Oct 30 04:26:27 triggr caddy[2316432]: JOURNAL_STREAM=8:13877949
Oct 30 04:26:27 triggr caddy[2316432]: SYSTEMD_EXEC_PID=2316432
Oct 30 04:26:27 triggr caddy[2316432]: {"level":"info","ts":1698639987.9060867,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 04:26:27 triggr caddy[2316432]: Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp 127.0.0.1:2019: bind: address already in use
Oct 30 04:26:27 triggr systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Oct 30 04:26:27 triggr systemd[1]: caddy.service: Failed with result 'exit-code'.
Oct 30 04:26:27 triggr systemd[1]: Failed to start Caddy.
Oct 30 04:32:21 triggr systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Oct 30 04:37:55 triggr systemd[1]: Starting Caddy...
Oct 30 04:37:55 triggr caddy[2317950]: caddy.HomeDir=/var/lib/caddy
Oct 30 04:37:55 triggr caddy[2317950]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 04:37:55 triggr caddy[2317950]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 04:37:55 triggr caddy[2317950]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 04:37:55 triggr caddy[2317950]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 04:37:55 triggr caddy[2317950]: runtime.GOOS=linux
Oct 30 04:37:55 triggr caddy[2317950]: runtime.GOARCH=amd64
Oct 30 04:37:55 triggr caddy[2317950]: runtime.Compiler=gc
Oct 30 04:37:55 triggr caddy[2317950]: runtime.NumCPU=2
Oct 30 04:37:55 triggr caddy[2317950]: runtime.GOMAXPROCS=2
Oct 30 04:37:55 triggr caddy[2317950]: runtime.Version=go1.21.3
Oct 30 04:37:55 triggr caddy[2317950]: os.Getwd=/
Oct 30 04:37:55 triggr caddy[2317950]: LANG=C.UTF-8
Oct 30 04:37:55 triggr caddy[2317950]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 04:37:55 triggr caddy[2317950]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 04:37:55 triggr caddy[2317950]: HOME=/var/lib/caddy
Oct 30 04:37:55 triggr caddy[2317950]: LOGNAME=caddy
Oct 30 04:37:55 triggr caddy[2317950]: USER=caddy
Oct 30 04:37:55 triggr caddy[2317950]: INVOCATION_ID=63b33af5055043f2b7e26f21ba1eb897
Oct 30 04:37:55 triggr caddy[2317950]: JOURNAL_STREAM=8:13890593
Oct 30 04:37:55 triggr caddy[2317950]: SYSTEMD_EXEC_PID=2317950
Oct 30 04:37:55 triggr caddy[2317950]: {"level":"info","ts":1698640675.4409306,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 04:37:55 triggr caddy[2317950]: Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp 127.0.0.1:2019: bind: address already in use
Oct 30 04:37:55 triggr systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Oct 30 04:37:55 triggr systemd[1]: caddy.service: Failed with result 'exit-code'.
Oct 30 04:37:55 triggr systemd[1]: Failed to start Caddy.
Oct 30 05:40:19 triggr systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Oct 30 05:40:45 triggr systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Oct 30 05:40:51 triggr systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Oct 30 05:41:01 triggr systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Oct 30 05:47:48 triggr systemd[1]: caddy.service: Unit cannot be reloaded because it is inactive.
Oct 30 05:47:56 triggr systemd[1]: Starting Caddy...
Oct 30 05:47:56 triggr caddy[2320321]: caddy.HomeDir=/var/lib/caddy
Oct 30 05:47:56 triggr caddy[2320321]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 05:47:56 triggr caddy[2320321]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 05:47:56 triggr caddy[2320321]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 05:47:56 triggr caddy[2320321]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 05:47:56 triggr caddy[2320321]: runtime.GOOS=linux
Oct 30 05:47:56 triggr caddy[2320321]: runtime.GOARCH=amd64
Oct 30 05:47:56 triggr caddy[2320321]: runtime.Compiler=gc
Oct 30 05:47:56 triggr caddy[2320321]: runtime.NumCPU=2
Oct 30 05:47:56 triggr caddy[2320321]: runtime.GOMAXPROCS=2
Oct 30 05:47:56 triggr caddy[2320321]: runtime.Version=go1.21.3
Oct 30 05:47:56 triggr caddy[2320321]: os.Getwd=/
Oct 30 05:47:56 triggr caddy[2320321]: LANG=C.UTF-8
Oct 30 05:47:56 triggr caddy[2320321]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 05:47:56 triggr caddy[2320321]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 05:47:56 triggr caddy[2320321]: HOME=/var/lib/caddy
Oct 30 05:47:56 triggr caddy[2320321]: LOGNAME=caddy
Oct 30 05:47:56 triggr caddy[2320321]: USER=caddy
Oct 30 05:47:56 triggr caddy[2320321]: INVOCATION_ID=102ab39979404bfc9bdd41337aa85501
Oct 30 05:47:56 triggr caddy[2320321]: JOURNAL_STREAM=8:13904326
Oct 30 05:47:56 triggr caddy[2320321]: SYSTEMD_EXEC_PID=2320321
Oct 30 05:47:56 triggr caddy[2320321]: {"level":"info","ts":1698644876.6241205,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 05:47:56 triggr caddy[2320321]: Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp 127.0.0.1:2019: bind: address already in use
Oct 30 05:47:56 triggr systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Oct 30 05:47:56 triggr systemd[1]: caddy.service: Failed with result 'exit-code'.
Oct 30 05:47:56 triggr systemd[1]: Failed to start Caddy.
Oct 30 05:51:23 triggr systemd[1]: Starting Caddy...
Oct 30 05:51:23 triggr caddy[2321013]: caddy.HomeDir=/var/lib/caddy
Oct 30 05:51:23 triggr caddy[2321013]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
Oct 30 05:51:23 triggr caddy[2321013]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
Oct 30 05:51:23 triggr caddy[2321013]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
Oct 30 05:51:23 triggr caddy[2321013]: caddy.Version=v2.7.5 h1:HoysvZkLcN2xJExEepaFHK92Qgs7xAiCFydN5x5Hs6Q=
Oct 30 05:51:23 triggr caddy[2321013]: runtime.GOOS=linux
Oct 30 05:51:23 triggr caddy[2321013]: runtime.GOARCH=amd64
Oct 30 05:51:23 triggr caddy[2321013]: runtime.Compiler=gc
Oct 30 05:51:23 triggr caddy[2321013]: runtime.NumCPU=2
Oct 30 05:51:23 triggr caddy[2321013]: runtime.GOMAXPROCS=2
Oct 30 05:51:23 triggr caddy[2321013]: runtime.Version=go1.21.3
Oct 30 05:51:23 triggr caddy[2321013]: os.Getwd=/
Oct 30 05:51:23 triggr caddy[2321013]: LANG=C.UTF-8
Oct 30 05:51:23 triggr caddy[2321013]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
Oct 30 05:51:23 triggr caddy[2321013]: NOTIFY_SOCKET=/run/systemd/notify
Oct 30 05:51:23 triggr caddy[2321013]: HOME=/var/lib/caddy
Oct 30 05:51:23 triggr caddy[2321013]: LOGNAME=caddy
Oct 30 05:51:23 triggr caddy[2321013]: USER=caddy
Oct 30 05:51:23 triggr caddy[2321013]: INVOCATION_ID=735bc805ae7e4ba1af70eaba18f05af5
Oct 30 05:51:23 triggr caddy[2321013]: JOURNAL_STREAM=8:13911706
Oct 30 05:51:23 triggr caddy[2321013]: SYSTEMD_EXEC_PID=2321013
Oct 30 05:51:23 triggr caddy[2321013]: {"level":"info","ts":1698645083.0637424,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":""}
Oct 30 05:51:23 triggr caddy[2321013]: Error: loading initial config: loading new config: starting caddy administration endpoint: listen tcp 127.0.0.1:2019: bind: address already in use
Oct 30 05:51:23 triggr systemd[1]: caddy.service: Main process exited, code=exited, status=1/FAILURE
Oct 30 05:51:23 triggr systemd[1]: caddy.service: Failed with result 'exit-code'.
Oct 30 05:51:23 triggr systemd[1]: Failed to start Caddy.
