spitfire
(spitfire)
September 8, 2016, 7:56pm
1
I’m trying to get Xdebug to connect back to PhpStorm. Xdebug connects with PhpStorm properly with built-in Php web server but not with Caddy.
Here’s my Caddyfile:
root www
errors visible
gzip
browse
tls off
fastcgi / 127.0.0.1:9001 php
Starting php-cgi.exe with
php-cgi.exe -b 127.0.0.1:9001
Xdebug configuration in php.ini:
zend_extension=php_xdebug.dll
xdebug.remote_enable=on
xdebug.remote_handler=dbgp
xdebug.remote_connect_back=1
xdebug.remote_port=9000
xdebug.cli_color=1
Any ideas?
System:
Windows 10 64-bit
Php 7.0.10 with Xdebug 2.4.1
Caddy 0.9.1
Thanks!
abiosoft
(Abiola Ibrahim)
September 8, 2016, 8:52pm
2
Firstly, ensure that is the correct php.ini, you can verify that from the phpinfo page.
What is the port configuration on PhpStorm ?
spitfire
(spitfire)
September 9, 2016, 2:38am
3
The php.ini path is correct as displayed by phpinfo(). The port in PhpStorm is 9000.
matt
(Matt Holt)
September 9, 2016, 3:01am
4
The first line of your Caddyfile must be the address of the site you’re serving. Did you intend to serve it on addresses root and www?
spitfire
(spitfire)
September 9, 2016, 1:57pm
5
Apologize. Yes, I missed copying the outer lines. My full Caddyfile is:
localhost:8080 {
root www
errors visible
gzip
browse
tls off
Here’s my test PHP index.php file:
<?php
$var = 'Hello World';
echo $var;
var_dump($_COOKIE);
The breakpoint is set on the second line $var = 'Hello World';. The dump shows that XDEBUG_SESSION has been properly set by PhpStorm bookmarklet in Chrome:
Hello World
Z:\Server\CaddyTest\www\index.php:4:
array (size=1)
'XDEBUG_SESSION' => string 'PHPSTORM' (length=8)
spitfire
(spitfire)
October 18, 2016, 2:46pm
6
Still not able to get Xdebug to connect back to PhpStorm with Caddy 0.9.3. Anybody have any luck?
xtfer
(Christopher Skene)
December 8, 2016, 2:46am
7
I’m having the same problem, fwiw.
system
(system)
Closed
March 8, 2017, 2:46am
8
