alexandzors
(Alexander Henderson)
February 18, 2019, 6:49am
1
Note sure exactly what is going on here but I am trying to setup wordpress on my root domain. Caddy is on one docker host while wordpress is on another…
Caddyfile:
www.domain.net, domain.net {
gzip
index index.hmtl index.htm
tls certs@domain.net
header / {
Content-Security-Policy
default-src "*"
X-Frame-Options "DENY"
Referrer-Policy "same-origin"
# rewrite {
# if {path} is /home
# to /external
# redir /external https://test.net
proxy / http://10.9.9.52 {
header_upstream Host {host}
header_upstream X-Forwarded-For {remote}
# rewrite {
# r /uploads\/(.*)\.php
# to /
# rewrite {
# if {path} not_match ^\/wp-admin
# to {path} {path}/ /index.php?{query}
proxy /portainer/ 10.9.9.52:9000 {
without /portainer
header_upstream -Connection
proxy /portainer/api/websocket/ 10.9.9.52:9000 {
without /portainer
websocket
proxy /ombi 10.9.9.132:3579 {
proxy /grafana/ http://10.9.9.132:3000 {
without /grafana/
websocket
redir /donate https://domain.net 302
log stdout
Error:
I type: domain.net and then url bar goes:
https://domain.net/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/index.php/
and chrome goes:
ERR_TOO_MANY_REDIRECTS
lol?
Also I tried just passing transparent and that didn’t work either.
I have also tried setting wordpress site and home page url to my root domain as well as editing the wp-config.php to check for reverse proxy headers…
Proxying to 10.9.9.52/index.php as your upstream probably has something to do with it…
Simplify it down. Try a simple proxy / 10.9.9.52 and see if that works.
P.S. index is unnecessary if every path is going to be proxied.
alexandzors
February 18, 2019, 1:33pm
3
I tried both ways. Neither seemed to work.
Just checking to confirm that:
www.example.com, example.com {
proxy / 10.9.9.52
Isn’t working? Does it produce the same problem (infinite redirection)?
alexandzors
February 18, 2019, 1:40pm
5
Yup. That way also produces the redirect issue.
Alright, I think we may have to troubleshoot the upstream itself, then.
Can you give us the output of curl -IL https://www.example.com as well as curl -IL 10.9.9.52 from the Caddy host?
If they redirect a lot, feel free to post the whole chain anyway (it’ll put a scroll bar down inside the preformatted block).
alexandzors
February 18, 2019, 2:26pm
7
OK well apparently I am dumb. The IP should have actually been 10.9.9.132. Which I fixed but now its failing to load any resources and instead just loads a basic html page with no formatting.
Failed to load resource: net::ERR_CONNECTION_TIMED_OUT
New Caddyfile:
www.alexsguardian.net, alexsguardian.net {
gzip
tls certs@alexsguardian.net
header / {
default-src "*"
# rewrite {
# to /external
# redir /external test.com
proxy / http://10.9.9.132 {
also removing the http:// results in this:
GET https://10.9.9.132/wp-content/themes/twentynineteen/print.css?ver=1.2 net::ERR_NETWORK_CHANGED
alexandzors
February 18, 2019, 2:31pm
8
alex@pc:~$ curl -Il https://www.alexsguardian.net
HTTP/1.1 301 Moved Permanently
Date: Mon, 18 Feb 2019 14:30:43 GMT
Content-Type: text/html; charset=utf-8
Connection: keep-alive
Set-Cookie: __cfduid=d40a281428ea3115af16b507467cba1861550500243; expires=Tue, 18-Feb-20 14:30:43 GMT; path=/; domain=.alexsguardian.net; HttpOnly
Server: cloudflare
CF-RAY: 4ab13178f8fb578f-IAD
alexander@andromeda:~$ curl -Il 10.9.9.132
HTTP/1.1 200 OK
Date: Mon, 18 Feb 2019 14:21:50 GMT
Server: Apache/2.4.25 (Debian)
X-Powered-By: PHP/7.2.15
Link: <http://10.9.9.132/wp-json/>; rel="https://api.w.org/"
Content-Type: text/html; charset=UTF-8
alexandzors
February 18, 2019, 5:57pm
9
Fixed it.
re-added
define( 'WP_HOME', 'http://alexsguardian.net' );
define( 'WP_SITEURL', 'http://alexsguardian.net' );
to wp-config.php and restarted wordpress. Now it works.
system
(system)
Closed
May 19, 2019, 5:57pm
10
