v2.4.5
ubuntu, docker
docker-compose up
version: "3.7"
image: caddy
- caddy_data:/data
- caddy_config:/config
caddy_data:
external: true
caddy_config:
# domain name.
media.ryanrambharose.dev {
#root * /usr/share/caddy
#file_server
reverse_proxy jellyfin:8096
# php_fastcgi localhost:9000
bitwarden.ryanrambharose.dev {
reverse_proxy bitwarden:8013
portainer.ryanrambharose.dev {
reverse_proxy portainer:9001
chat.ryanrambharose.dev {
reverse_proxy synapse:8008
chat.ryanrambharose.dev:8448 {
irc.ryanrambharose.dev {
reverse_proxy thelounge:9000
pihole.ryanrambharose.dev {
reverse_proxy pihole:8009
Run Caddy with Dockstarter and Docker
caddy_1 | {“level”:“error”,“ts”:1636127149.278481,“logger”:“http.log.error”,“msg”:“dial tcp: lookup portainer on 127.0.0.11:53: no such host”,“request”:{“remote_addr”:“174.92.13.211:51687”,“proto”:“HTTP/2.0”,“method”:“GET”,“host”:“portainer.ryanrambharose.dev”,“uri”:"/",“headers”:{“User-Agent”:[“Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/95.0.4638.54 Safari/537.36”],“Sec-Fetch-Site”:[“none”],“Sec-Fetch-Mode”:[“navigate”],“Sec-Fetch-User”:["?1"],“Cache-Control”:[“max-age=0”],“Sec-Ch-Ua”:["“Chromium”;v=“95”, “;Not A Brand”;v=“99"”],“Sec-Ch-Ua-Mobile”:["?0"],“Sec-Ch-Ua-Platform”:["“Windows”"],“Upgrade-Insecure-Requests”:[“1”],“Accept”:[“text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9”],“Sec-Fetch-Dest”:[“document”],“Accept-Encoding”:[“gzip, deflate, br”],“Accept-Language”:[“en-US,en;q=0.9”]},“tls”:{“resumed”:false,“version”:772,“cipher_suite”:4865,“proto”:“h2”,“proto_mutual”:true,“server_name”:“portainer.ryanrambharose.dev”}},“duration”:0.002577361,“status”:502,“err_id”:“26f9egj6t”,“err_trace”:“reverseproxy.statusError (reverseproxy.go:858)”}
Instead of localhost I set it to the docker container name and port. I think the issue might be due to networks being different?
