Caddy and cloudflare
caddy validate fails with unrecognized global option: trusted_proxies even on a minimal Caddyfile.
  • Minimal Caddyfile that Fails:
    trusted_proxies {
    source cloudflare
http://localhost:8080 {
respond “Test OK”
Error: adapting config using caddyfile: /etc/caddy/Caddyfile:2: unrecognized global option: trusted_proxies
Caddy Version: v2.9.1
apt get install
Ubuntu 20.04 LTS
caddy validate --config /etc/caddy/Caddyfile2025/04/11 23:28:18.502 INFO    using config from file  {"file": "/etc/caddy/Caddyfile"}
    trusted_proxies {
        source cloudflare
    respond "Test OK"
Currently, only the static IP source module is included with the standard distribution of Caddy, but this can be extended with plugins to maintain a dynamic list of IP ranges.
According to the official Caddy documentation for v2.9.1 (Global options (Caddyfile) — Caddy Documentation), the cloudflare source is built-in to the standard Caddy distribution.
More over the error is: unrecognized global option: trusted_proxies.
Caddy isn’t recognizing the directive name trusted_proxies itself when placed in the global options block
Where’s servers?
That’s not true. Where does the doc say this? The documentation page says:
This placement is wrong
It goes inside servers. Refer to the example in the doc page.
Problem solved. It works with static IP source module. Thank you
