I am trying to renew my SSL certificate from Cloudflare, but when I run caddy -log stderr I get the following warning: “Cloudflare credentials missing”. I have my email and API key but I have not been able to find instructions on where I need to add these items in order for my certificate to renew.
That’s highly dependent on the environment you’re deploying Caddy in.
Assuming you’re on one of the common flavours of Linux, the simplest way would be to type CLOUDFLARE_EMAIL=myemail@example.com and CLOUDFLARE_API_KEY=123xyz in the shell before running Caddy.
If you plan to use an init system to run Caddy for you, you’ll need to make sure it handles setting the variables - again, depends highly on the system you use.
