Caddy2
I am using Caddy in a docker from dockerhub.
Works fine, just need help to find out how to use cgi in the docker image
Docker, linux
paste command here
version: '3.5'
image: caddy
container_name: caddy_web_proxy
- ./certs:/data/caddy # to save certificates on disk
- ./Caddyfile:/etc/caddy/Caddyfile # to mount custom Caddyfile
#network_mode: host
web-backend-network:
aliases:
- caddy
driver: bridge
driver_opts:
com.docker.network.bridge.name: br-web-caddy
ipam:
driver: default
homeassistent.xxx.xxx.xxx, homeassistant.xxx.xxx.xxx {
reverse_proxy homeassistent:8123
webkey.xxx.xxx.xxx {
cgi /publickey.sh /srv/webkey/publickey.sh
caddy_web_proxy | {“level”:“info”,“ts”:1590773428.563543,“msg”:“autosaved config”,“file”:“/config/caddy/autosave.json”}
caddy_web_proxy | {“level”:“info”,“ts”:1590773428.5636163,“msg”:“serving initial configuration”}
caddy_web_proxy | {“level”:“info”,“ts”:1590773705.99914,“msg”:“shutting down apps then terminating”,“signal”:“SIGTERM”}
caddy_web_proxy | 2020/05/29 17:35:05 [INFO][cache:0x3e20080] Stopped certificate maintenance routine
caddy_web_proxy | {“level”:“info”,“ts”:1590773706.000049,“logger”:“admin”,“msg”:“stopped previous server”}
caddy_web_proxy | {“level”:“info”,“ts”:1590773706.0000997,“msg”:“shutdown done”,“signal”:“SIGTERM”}
caddy_web_proxy | {“level”:“info”,“ts”:1590773709.5495799,“msg”:“using provided configuration”,“config_file”:“/etc/caddy/Caddyfile”,“config_adapter”:“caddyfile”}
caddy_web_proxy | run: adapting config using caddyfile: /etc/caddy/Caddyfile:8: unrecognized directive: cgi
I searched to Caddy2 documentation but I could not find anything about cgi, only fastcgi.
