Caddy add-package/upgrade always use older versions of modules
love4taylor@au-tokyo-n1:~$ sudo caddy add-package github.com/RussellLuo/caddy-ext/ratelimit
2023/05/07 00:03:59.351	INFO	this executable will be replaced	{"path": "/usr/bin/caddy"}
2023/05/07 00:03:59.351	INFO	requesting build	{"os": "linux", "arch": "amd64", "packages": ["github.com/caddy-dns/cloudflare", "github.com/caddy-dns/dnspod", "github.com/RussellLuo/caddy-ext/ratelimit", "github.com/mholt/caddy-webdav", "github.com/WeidiDeng/caddy-cloudflare-ip"]}
2023/05/07 00:03:59.747	INFO	build acquired; backing up current executable	{"current_path": "/usr/bin/caddy", "backup_path": "/usr/bin/caddy.tmp"}
2023/05/07 00:03:59.747	INFO	downloading binary	{"destination": "/usr/bin/caddy"}
2023/05/07 00:04:01.550	INFO	download successful; displaying new binary details	{"location": "/usr/bin/caddy"}
Module versions:
panic: Something in this program imports go4.org/unsafe/assume-no-moving-gc to declare that it assumes a non-moving garbage collector, but your version of go4.org/unsafe/assume-no-moving-gc hasn't been updated to assert that it's safe against the go1.20 runtime. If you want to risk it, run with environment variable ASSUME_NO_MOVING_GC_UNSAFE_RISK_IT_WITH=go1.20 set. Notably, if go1.20 adds a moving garbage collector, this program is unsafe to use.
goroutine 1 [running]:
go4.org/unsafe/assume-no-moving-gc.init.0()
	go4.org/unsafe/assume-no-moving-gc@v0.0.0-20220617031537-928513b29760/untested.go:25 +0x1ba
Error: download succeeded, but unable to execute 'caddy list-modules': exit status 2
This commit has fixed the assume-no-moving-gc issue, but it seems that the official caddy builder doesn’t use the latest code. I can successfully build with xcaddy + go1.20.3
The developer created a new tag and pressed the rescan button in the caddyserver.com dashboard but the problem persists.
Hmm, the build server is already running the latest xcaddy with Go 1.20.3. What are the differences in caddy build-info between your custom-built binary and the one that got downloaded?
If I don’t add ASSUME_NO_MOVING_GC_UNSAFE_RISK_IT_WITH=go1.20 I can’t download the binary file
love4taylor@au-tokyo-n1:~/caddy$ ./caddy add-package github.com/RussellLuo/caddy-ext/ratelimit
2023/05/07 03:52:34.558	INFO	this executable will be replaced	{"path": "/home/love4taylor/caddy/caddy"}
2023/05/07 03:52:34.558	INFO	requesting build	{"os": "linux", "arch": "amd64", "packages": ["github.com/RussellLuo/caddy-ext/ratelimit"]}
2023/05/07 03:52:34.930	INFO	build acquired; backing up current executable	{"current_path": "/home/love4taylor/caddy/caddy", "backup_path": "/home/love4taylor/caddy/caddy.tmp"}
2023/05/07 03:52:34.931	INFO	downloading binary	{"destination": "/home/love4taylor/caddy/caddy"}
2023/05/07 03:52:37.240	INFO	download successful; displaying new binary details	{"location": "/home/love4taylor/caddy/caddy"}
Module versions:
love4taylor@au-tokyo-n1:~/caddy$ ASSUME_NO_MOVING_GC_UNSAFE_RISK_IT_WITH=go1.20 ./caddy add-package github.com/RussellLuo/caddy-ext/ratelimit
2023/05/07 03:52:55.202	INFO	this executable will be replaced	{"path": "/home/love4taylor/caddy/caddy"}
2023/05/07 03:52:55.202	INFO	requesting build	{"os": "linux", "arch": "amd64", "packages": ["github.com/RussellLuo/caddy-ext/ratelimit"]}
2023/05/07 03:52:55.552	INFO	build acquired; backing up current executable	{"current_path": "/home/love4taylor/caddy/caddy", "backup_path": "/home/love4taylor/caddy/caddy.tmp"}
2023/05/07 03:52:55.552	INFO	downloading binary	{"destination": "/home/love4taylor/caddy/caddy"}
2023/05/07 03:52:57.541	INFO	download successful; displaying new binary details	{"location": "/home/love4taylor/caddy/caddy"}
Module versions:
http.handlers.rate_limit v0.2.0
  Non-standard modules: 1
  Unknown modules: 0
Version:
2023/05/07 03:52:57.638	INFO	upgrade successful; please restart any running Caddy instances	{"executable": "/home/love4taylor/caddy/caddy"}
If I don’t add ASSUME_NO_MOVING_GC_UNSAFE_RISK_IT_WITH=go1.20 I can’t get build-info
love4taylor@au-tokyo-n1:~/caddy$ ./caddy build-info
love4taylor@au-tokyo-n1:~/caddy$ ASSUME_NO_MOVING_GC_UNSAFE_RISK_IT_WITH=go1.20 ./caddy build-info
go	go1.20.3
path	caddy
mod	caddy	(devel)
dep	filippo.io/edwards25519	v1.0.0	h1:0wAIcmJUqRdI8IJ/3eGi5/HwXZWPujYXXlkrQogz0Ek=
dep	github.com/AndreasBriese/bbloom	v0.0.0-20190825152654-46b345b51c96	h1:cTp8I5+VIoKjsnZuH8vjyaysT/ses3EvZeaV/1UkF2M=
dep	github.com/BurntSushi/toml	v1.2.1	h1:9F2/+DoOYIOksmaJFPw1tGFy1eDnIJXg+UHjuD8lTak=
dep	github.com/Masterminds/goutils	v1.1.1	h1:5nUrii3FMTL5diU80unEVvNevw1nH4+ZV4DSLVJLSYI=
dep	github.com/Masterminds/semver/v3	v3.2.0	h1:3MEsd0SM6jqZojhjLWWeBY+Kcjy9i6MQAeY7YgDP83g=
dep	github.com/Masterminds/sprig/v3	v3.2.3	h1:eL2fZNezLomi0uOLqjQoN6BfsDD+fyLtgbJMAj9n6YA=
dep	github.com/RussellLuo/caddy-ext/ratelimit	v0.2.0	h1:mmJf/edJ2gu1NbEZHsgVlNABVoigZqMTwbILq3ueNIc=
dep	github.com/RussellLuo/slidingwindow	v0.0.0-20200528002341-535bb99d338b	h1:5/++qT1/z812ZqBvqQt6ToRswSuPZ/B33m6xVHRzADU=
dep	github.com/alecthomas/chroma/v2	v2.5.0	h1:CQCdj1BiBV17sD4Bd32b/Bzuiq/EqoNTrnIhyQAZ+Rk=
dep	github.com/antlr/antlr4/runtime/Go/antlr	v1.4.10	h1:yL7+Jz0jTC6yykIK/Wh74gnTJnrGr5AyrNMXuA0gves=
dep	github.com/aryann/difflib	v0.0.0-20210328193216-ff5ff6dc229b	h1:uUXgbcPDK3KpW29o4iy7GtuappbWT0l5NaMo9H9pJDw=
dep	github.com/beorn7/perks	v1.0.1	h1:VlbKKnNfV8bJzeqoa4cOKqO6bYr3WgKZxO8Z16+hsOM=
dep	github.com/caddyserver/caddy/v2	v2.6.4	h1:2hwYqiRwk1tf3VruhMpLcYTg+11fCdr8S3jhNAdnPy8=
dep	github.com/caddyserver/certmagic	v0.17.2	h1:o30seC1T/dBqBCNNGNHWwj2i5/I/FMjBbTAhjADP3nE=
dep	github.com/cenkalti/backoff/v4	v4.1.2	h1:6Yo7N8UP2K6LWZnW94DLVSSrbobcWdVzAYOisuDPIFo=
dep	github.com/cespare/xxhash	v1.1.0	h1:a6HrQnmkObjyL+Gs60czilIUGqrzKutQD6XZog3p+ko=
dep	github.com/cespare/xxhash/v2	v2.1.2	h1:YRXhKfTDauu4ajMg1TPgFO5jnlC2HCbmLXMcTG5cbYE=
dep	github.com/chzyer/readline	v0.0.0-20180603132655-2972be24d48e	h1:fY5BOSpyZCqRo5OhCuC+XN+r/bBCmeuuJtjz+bCNIf8=
dep	github.com/cpuguy83/go-md2man/v2	v2.0.2	h1:p1EgwI/C7NhT0JmVkwCD2ZBK8j4aeHQX2pMHHBfMQ6w=
dep	github.com/dgraph-io/badger	v1.6.2	h1:mNw0qs90GVgGGWylh0umH5iag1j6n/PeJtNvL6KY/x8=
dep	github.com/dgraph-io/badger/v2	v2.2007.4	h1:TRWBQg8UrlUhaFdco01nO2uXwzKS7zd+HVdwV/GHc4o=
dep	github.com/dgraph-io/ristretto	v0.1.0	h1:Jv3CGQHp9OjuMBSne1485aDpUkTKEcUqF+jm/LuerPI=
dep	github.com/dgryski/go-farm	v0.0.0-20200201041132-a6ae2369ad13	h1:fAjc9m62+UWV/WAFKLNi6ZS0675eEUC9y3AlwSbQu1Y=
dep	github.com/dlclark/regexp2	v1.7.0	h1:7lJfhqlPssTb1WQx4yvTHN0uElPEv52sbaECrAQxjAo=
dep	github.com/dustin/go-humanize	v1.0.1	h1:GzkhY7T5VNhEkwH0PVJgjz+fX1rhBrR7pRT3mDkpeCY=
dep	github.com/felixge/httpsnoop	v1.0.3	h1:s/nj+GCswXYzN5v2DpNMuMQYe+0DDwt5WVCU6CWBdXk=
dep	github.com/fxamacker/cbor/v2	v2.4.0	h1:ri0ArlOR+5XunOP8CRUowT0pSJOwhW098ZCUyskZD88=
dep	github.com/go-chi/chi	v4.1.2+incompatible	h1:fGFk2Gmi/YKXk0OmGfBh0WgmN3XB8lVnEyNz34tQRec=
dep	github.com/go-kit/kit	v0.10.0	h1:dXFJfIHVvUcpSgDOV+Ne6t7jXri8Tfv2uOLHUZ2XNuo=
dep	github.com/go-logfmt/logfmt	v0.5.1	h1:otpy5pqBCBZ1ng9RQ0dPu4PN7ba75Y/aA+UpowDyNVA=
dep	github.com/go-logr/logr	v1.2.3	h1:2DntVwHkVopvECVRSlL5PSo9eG+cAkDCuckLubN+rq0=
dep	github.com/go-logr/stdr	v1.2.2	h1:hSWxHoqTgW2S2qGc0LTAI563KZ5YKYRhT3MFKZMbjag=
dep	github.com/go-sql-driver/mysql	v1.6.0	h1:BCTh4TKNUYmOmMUcQ3IipzF5prigylS7XXjEkfCHuOE=
dep	github.com/golang/glog	v1.0.0	h1:nfP3RFugxnNRyKgeWd4oI1nYvXpxrx8ck8ZrcizshdQ=
dep	github.com/golang/protobuf	v1.5.2	h1:ROPKBNFfQgOUMifHyP+KYbvpjbdoFNs+aK7DXlji0Tw=
dep	github.com/golang/snappy	v0.0.4	h1:yAGX7huGHXlcLOEtBnF4w7FQwA26wojNCwOYAEhLjQM=
dep	github.com/google/cel-go	v0.13.0	h1:z+8OBOcmh7IeKyqwT/6IlnMvy621fYUqnTVPEdegGlU=
dep	github.com/google/uuid	v1.3.0	h1:t6JiXgmwXMjEs8VusXIJk2BXHsn+wx8BZdTaoZ5fu7I=
dep	github.com/grpc-ecosystem/grpc-gateway	v1.16.0	h1:gmcG1KaJ57LophUzW0Hy8NmPhnMZb4M0+kPpLofRdBo=
dep	github.com/hashicorp/golang-lru	v0.5.4	h1:YDjusn29QI/Das2iO9M0BHnIbxPeyuCHsjMW+lJfyTc=
dep	github.com/huandu/xstrings	v1.3.3	h1:/Gcsuc1x8JVbJ9/rlye4xZnVAbEkGauT8lbebqcQws4=
dep	github.com/imdario/mergo	v0.3.12	h1:b6R2BslTbIEToALKP7LxUvijTsNI9TAe80pLWN2g/HU=
dep	github.com/jackc/chunkreader/v2	v2.0.1	h1:i+RDz65UE+mmpjTfyz0MoVTnzeYxroil2G82ki7MGG8=
dep	github.com/jackc/pgconn	v1.13.0	h1:3L1XMNV2Zvca/8BYhzcRFS70Lr0WlDg16Di6SFGAbys=
dep	github.com/jackc/pgio	v1.0.0	h1:g12B9UwVnzGhueNavwioyEEpAmqMe1E/BN9ES+8ovkE=
dep	github.com/jackc/pgpassfile	v1.0.0	h1:/6Hmqy13Ss2zCq62VdNG8tM1wchn8zjSGOBJ6icpsIM=
dep	github.com/jackc/pgproto3/v2	v2.3.1	h1:nwj7qwf0S+Q7ISFfBndqeLwSwxs+4DPsbRFjECT1Y4Y=
dep	github.com/jackc/pgservicefile	v0.0.0-20200714003250-2b9c44734f2b	h1:C8S2+VttkHFdOOCXJe+YGfa4vHYwlt4Zx+IVXQ97jYg=
dep	github.com/jackc/pgtype	v1.12.0	h1:Dlq8Qvcch7kiehm8wPGIW0W3KsCCHJnRacKW0UM8n5w=
dep	github.com/jackc/pgx/v4	v4.17.2	h1:0Ut0rpeKwvIVbMQ1KbMBU4h6wxehBI535LK6Flheh8E=
dep	github.com/klauspost/compress	v1.15.15	h1:EF27CXIuDsYJ6mmvtBRlEuB2UVOqHG1tAXgZ7yIO+lw=
dep	github.com/klauspost/cpuid/v2	v2.2.3	h1:sxCkb+qR91z4vsqw4vGGZlDgPz3G7gjaLyK3V8y70BU=
dep	github.com/libdns/libdns	v0.2.1	h1:Wu59T7wSHRgtA0cfxC+n1c/e+O3upJGWytknkmFEDis=
dep	github.com/manifoldco/promptui	v0.9.0	h1:3V4HzJk1TtXW1MTZMP7mdlwbBpIinw3HztaIlYthEiA=
dep	github.com/mattn/go-colorable	v0.1.8	h1:c1ghPdyEDarC70ftn0y+A/Ee++9zz8ljHG1b13eJ0s8=
dep	github.com/mattn/go-isatty	v0.0.13	h1:qdl+GuBjcsKKDco5BsxPJlId98mSWNKqYA+Co0SC1yA=
dep	github.com/matttproud/golang_protobuf_extensions	v1.0.1	h1:4hp9jkHxhMHkqkrB3Ix0jegS5sx/RkqARlsWZ6pIwiU=
dep	github.com/mgutz/ansi	v0.0.0-20200706080929-d51e80ef957d	h1:5PJl274Y63IEHC+7izoQE9x6ikvDFZS2mDVS3drnohI=
dep	github.com/mholt/acmez	v1.1.0	h1:IQ9CGHKOHokorxnffsqDvmmE30mDenO1lptYZ1AYkHY=
dep	github.com/micromdm/scep/v2	v2.1.0	h1:2fS9Rla7qRR266hvUoEauBJ7J6FhgssEiq2OkSKXmaU=
dep	github.com/miekg/dns	v1.1.50	h1:DQUfb9uc6smULcREF09Uc+/Gd46YWqJd5DbpPE9xkcA=
dep	github.com/mitchellh/copystructure	v1.2.0	h1:vpKXTN4ewci03Vljg/q9QvCGUDttBOGBIa15WveJJGw=
dep	github.com/mitchellh/go-ps	v1.0.0	h1:i6ampVEEF4wQFF+bkYfwYgY+F/uYJDktmvLPf7qIgjc=
dep	github.com/mitchellh/reflectwalk	v1.0.2	h1:G2LzWKi524PWgd3mLHV8Y5k7s6XUvT0Gef6zxSIeXaQ=
dep	github.com/pkg/errors	v0.9.1	h1:FEBLx1zS214owpjy7qsBeixbURkuhQAwrK5UwLGTwt4=
dep	github.com/prometheus/client_golang	v1.14.0	h1:nJdhIvne2eSX/XRAFV9PcvFFRbrjbcTUj0VP62TMhnw=
dep	github.com/prometheus/client_model	v0.3.0	h1:UBgGFHqYdG/TPFD1B1ogZywDqEkwp3fBMvqdiQ7Xew4=
dep	github.com/prometheus/common	v0.37.0	h1:ccBbHCgIiT9uSoFY0vX8H3zsNR5eLt17/RQLUvn8pXE=
dep	github.com/prometheus/procfs	v0.8.0	h1:ODq8ZFEaYeCaZOJlZZdJA2AbQR98dSHSM1KW/You5mo=
dep	github.com/quic-go/qpack	v0.4.0	h1:Cr9BXA1sQS2SmDUWjSofMPNKmvF6IiIfDRmgU0w1ZCo=
dep	github.com/quic-go/qtls-go1-20	v0.1.0	h1:d1PK3ErFy9t7zxKsG3NXBJXZjp/kMLoIb3y/kV54oAI=
dep	github.com/quic-go/quic-go	v0.32.0	h1:lY02md31s1JgPiiyfqJijpu/UX/Iun304FI3yUqX7tA=
dep	github.com/rs/xid	v1.4.0	h1:qd7wPTDkN6KQx2VmMBLrpHkiyQwgFXRnkOLacUiaSNY=
dep	github.com/russross/blackfriday/v2	v2.1.0	h1:JIOH55/0cWyOuilr9/qlrm0BSXldqnqwMsf35Ld67mk=
dep	github.com/shopspring/decimal	v1.2.0	h1:abSATXmQEYyShuxI4/vyW3tV1MrKAJzCZ/0zLUXYbsQ=
dep	github.com/shurcooL/sanitized_anchor_name	v1.0.0	h1:PdmoCO6wvbs+7yrJyMORt4/BmY5IYyJwS/kOiWx8mHo=
dep	github.com/sirupsen/logrus	v1.9.0	h1:trlNQbNUG3OdDrDil03MCb1H2o9nJ1x4/5LYw7byDE0=
dep	github.com/slackhq/nebula	v1.6.1	h1:/OCTR3abj0Sbf2nGoLUrdDXImrCv0ZVFpVPP5qa0DsM=
dep	github.com/smallstep/certificates	v0.23.2	h1:7KSx9WfZ3CILV0XlsTrl+PK58YE4CHSgqobB6+ieQWs=
dep	github.com/smallstep/nosql	v0.5.0	h1:1BPyHy8bha8qSaxgULGEdqhXpNFXimAfudnauFVqmxw=
dep	github.com/smallstep/truststore	v0.12.1	h1:guLUKkc1UlsXeS3t6BuVMa4leOOpdiv02PCRTiy1WdY=
dep	github.com/spf13/cast	v1.4.1	h1:s0hze+J0196ZfEMTs80N7UlFt0BDuQ7Q+JDnHiMWKdA=
dep	github.com/spf13/cobra	v1.6.1	h1:o94oiPyS4KD1mPy2fmcYYHHfCxLqYjJOhGsCHFZtEzA=
dep	github.com/spf13/pflag	v1.0.5	h1:iy+VFUOCP1a+8yFto/drg2CJ5u0yRoB7fZw3DKv/JXA=
dep	github.com/stoewer/go-strcase	v1.2.0	h1:Z2iHWqGXH00XYgqDmNgQbIBxf3wrNq0F3feEy0ainaU=
dep	github.com/tailscale/tscert	v0.0.0-20230124224810-c6dc1f4049b2	h1:TrgfmCXwtWyFw85UkRGXt9qZRzdzt3nWt2Rerdecn0w=
dep	github.com/urfave/cli	v1.22.12	h1:igJgVw1JdKH+trcLWLeLwZjU9fEfPesQ+9/e4MQ44S8=
dep	github.com/x448/float16	v0.8.4	h1:qLwI1I70+NjRFUR3zs1JPUCgaCXSh3SW62uAKT1mSBM=
dep	github.com/yuin/goldmark	v1.5.4	h1:2uY/xC0roWy8IBEGLgB1ywIoEJFGmRrX21YQcvGZzjU=
dep	github.com/yuin/goldmark-highlighting/v2	v2.0.0-20220924101305-151362477c8h1:Py16JEzkSdKAtEFJjiaYLYBOWGXc1r/xHj/Q/5lA37k=
dep	go.etcd.io/bbolt	v1.3.6	h1:/ecaJf0sk1l4l6V4awd65v2C3ILy7MSj+s/x1ADCIMU=
dep	go.mozilla.org/pkcs7	v0.0.0-20210826202110-33d05740a352	h1:CCriYyAfq1Br1aIYettdHZTy8mBTIPo7We18TuO/bak=
dep	go.opentelemetry.io/contrib/instrumentation/net/http/otelhttp	v0.39.0	h1:vFEBG7SieZJzvnRWQ81jxpuEqe6J8Ex+hgc9CqOTzHc=
dep	go.opentelemetry.io/otel	v1.13.0	h1:1ZAKnNQKwBBxFtww/GwxNUyTf0AxkZzrukO8MeXqe4Y=
dep	go.opentelemetry.io/otel/exporters/otlp/internal/retry	v1.4.0	h1:j7AwzDdAQBJjcqayAaYbvpYeZzII7cEe5qJTu+De6UY=
dep	go.opentelemetry.io/otel/exporters/otlp/otlptrace	v1.4.0	h1:lRpP10E8oTGVmY1nVXcwelCT1Z8ca41/l5ce7AqLAss=
dep	go.opentelemetry.io/otel/exporters/otlp/otlptrace/otlptracegrpc	v1.4.0	h1:buSx4AMC/0Z232slPhicN/fU5KIlj0bMngct5pcZhkI=
dep	go.opentelemetry.io/otel/metric	v0.36.0	h1:t0lgGI+L68QWt3QtOIlqM9gXoxqxWLhZ3R/e5oOAY0Q=
dep	go.opentelemetry.io/otel/sdk	v1.13.0	h1:BHib5g8MvdqS65yo2vV1s6Le42Hm6rrw08qU6yz5JaM=
dep	go.opentelemetry.io/otel/trace	v1.13.0	h1:CBgRZ6ntv+Amuj1jDsMhZtlAPT6gbyIRdaIzFhfBSdY=
dep	go.opentelemetry.io/proto/otlp	v0.12.0	h1:CMJ/3Wp7iOWES+CYLfnBv+DVmPbB+kmy9PJ92XvlR6c=
dep	go.step.sm/cli-utils	v0.7.5	h1:jyp6X8k8mN1B0uWJydTid0C++8tQhm2kaaAdXKQQzdk=
dep	go.step.sm/crypto	v0.23.2	h1:XGmQH9Pkpxop47cjYlUhF10L5roPCbu1BCZXopbeW8I=
dep	go.step.sm/linkedca	v0.19.0	h1:xuagkR35wrJI2gnu6FAM+q3VmjwsHScvGcJsfZ0GdsI=
dep	go.uber.org/atomic	v1.9.0	h1:ECmE8Bn/WFTYwEW/bpKD3M8VtR/zQVbavAoalC1PYyE=
dep	go.uber.org/multierr	v1.6.0	h1:y6IPFStTAIT5Ytl7/XYmHvzXQ7S3g/IeZW9hyZ5thw4=
dep	go.uber.org/zap	v1.24.0	h1:FiJd5l1UOLj0wCgbSE0rwwXHzEdAZS6hiiSnxJN/D60=
dep	go4.org/intern	v0.0.0-20220617035311-6925f38cc365	h1:t9hFvR102YlOqU0fQn1wgwhNvSbHGBbbJxX9JKfU3l0=
dep	go4.org/unsafe/assume-no-moving-gc	v0.0.0-20220617031537-928513b29760	h1:FyBZqvoA/jbNzuAWLQE2kG820zMAkcilx6BMjGbL/E4=
dep	golang.org/x/crypto	v0.5.0	h1:U/0M97KRkSFvyD/3FSmdP5W5swImpNgle/EHFhOsQPE=
dep	golang.org/x/exp	v0.0.0-20221205204356-47842c84f3db	h1:D/cFflL63o2KSLJIwjlcIt8PR064j/xsmdEJL/YvY/o=
dep	golang.org/x/net	v0.7.0	h1:rJrUqqhjsgNp7KqAIc25s9pZnjU7TUcSY7HcVZjdn1g=
dep	golang.org/x/sync	v0.1.0	h1:wsuoTGHzEhffawBOhz5CYhcrV4IdKZbEyZjBMuTp12o=
dep	golang.org/x/sys	v0.5.0	h1:MUK/U/4lj1t1oPg0HfuXDN/Z1wv31ZJ/YcPiGccS4DU=
dep	golang.org/x/term	v0.5.0	h1:n2a8QNdAb0sZNpU9R1ALUXBbY+w51fCQDN+7EdxNBsY=
dep	golang.org/x/text	v0.7.0	h1:4BRB4x83lYWy72KwLD/qYDuTu7q9PjSagHvijDw7cLo=
dep	google.golang.org/genproto	v0.0.0-20230202175211-008b39050e57	h1:vArvWooPH749rNHpBGgVl+U9B9dATjiEhJzcWGlovNs=
dep	google.golang.org/grpc	v1.52.3	h1:pf7sOysg4LdgBqduXveGKrcEwbStiK2rtfghdzlUYDQ=
dep	google.golang.org/protobuf	v1.28.1	h1:d0NfwRgPtno5B1Wa6L2DAG+KivqkdutMf1UhdNx175w=
dep	gopkg.in/natefinch/lumberjack.v2	v2.2.1	h1:bBRl1b0OH9s/DuPhuXpNl+VtCaJXFZ5/uEFST95x9zc=
dep	gopkg.in/square/go-jose.v2	v2.6.0	h1:NGk74WTnPKBNUhNzQX7PYcTLUjoq7mzKk2OKbvwk2iI=
dep	gopkg.in/yaml.v3	v3.0.1	h1:fxVm/GzAzEWqLHuvctI91KS9hhNmmWOoWu0XTYJS7CA=
dep	inet.af/netaddr	v0.0.0-20220811202034-502d2d690317	h1:U2fwK6P2EqmopP/hFLTOAjWTki0qgd4GMJn5X8wOleU=
build	-buildmode=exe
build	-compiler=gc
build	-trimpath=true
build	CGO_ENABLED=0
build	GOARCH=amd64
build	GOOS=linux
build	GOAMD64=v1
This is what I built using xcaddy:
love4taylor@au-tokyo-n1:~$ /tmp/caddy build-info
go	go1.20.3
path	caddy
mod	caddy	(devel)
dep	github.com/RussellLuo/caddy-ext/ratelimit	v0.3.0	h1:SgYjCUqW+Kh0qGjtS9zB4VtbI7rtCysVg+3ynxec3jo=
dep	github.com/WeidiDeng/caddy-cloudflare-ip	v0.0.0-20230304134258-b7299f8aed5h1:m80XrjH9rhilyz6PRBJ+kTBQAcec5sgAvZnwBkM1g4Y=
dep	github.com/caddy-dns/cloudflare	v0.0.0-20230224210553-a9d3ae2690a1	h1:otPG5SrMCkdaRgzvODLdaehryPY1/KwM3WcsuiM6d98=
dep	github.com/caddy-dns/dnspod	v0.0.4	h1:txebUF94u/Y8Wt6+hZCmBlD7UQFaNbUUMcAEq8PjgRk=
dep	github.com/libdns/cloudflare	v0.1.0	h1:93WkJaGaiXCe353LHEP36kAWCUw0YjFqwhkBkU2/iic=
dep	github.com/libdns/dnspod	v0.0.3	h1:xJHDIujgLjvZnpB8/rMoCHUqA/KxSGBqRUXxSIzNzAA=
dep	github.com/mholt/caddy-webdav	v0.0.0-20221206035947-75a603bc6978	h1:+yiDdLr2PPZZHSwuOBYf8ACRA4waDw+YVp/Jgbeuo0Y=
dep	github.com/nrdcg/dnspod-go	v0.4.0	h1:c/jn1mLZNKF3/osJ6mz3QPxTudvPArXTjpkmYj0uK6U=
build	-compiler=gc
build	CGO_ENABLED=0
build	GOARCH=amd64
build	GOOS=linux
build	GOAMD64=v1
The problem still exists until now.
