Caddy add-package hangs when trying to add lego-deprecated
I am trying to use caddy add-package to add lego-deprecated. I can add other packages, but with this one it hangs on requesting build.
app@myhost ~/p/api (main) [1]> caddy add-package github.com/caddy-dns/lego-deprecated
2023/05/12 03:28:27.569	INFO	this executable will be replaced	{"path": "/home/app/.local/opt/caddy-v2.6.4/bin/caddy"}
2023/05/12 03:28:27.569	INFO	requesting build	{"os": "linux", "arch": "amd64", "packages": ["github.com/caddy-dns/digitalocean", "github.com/caddy-dns/lego-deprecated"]}
Installed using webinstall.dev/caddy
ubuntu 20.04
amd64
N/A
N/A
That package is huge, it adds a lot of dependencies, hence why it’s deprecated. It continually brings the build server to its knees.
I suggest you build it on your own hardware with xcaddy instead.
This reminds me it’s probably time to remove that plugin from our website. It’s too expensive to build on our limited infrastructure and our newer, lighter caddy-dns packages support about 50 providers now, with more continually being contributed by the community.
I can rebuild it with xcaddy. Np. My reason for using lego is that dnsimple isn’t present in the current caddy-dns libs. Is there anything holding back caddy-dns/dnsimple other than nobody has written and tested it?
Yeah I think nobody’s written it yet. You could be the one to do it!
Yeah, as Francis said it hasn’t been written yet – but DNSimple is pretty fantastic, so I imagine their API is good. You should have no problem doing it I hope :crossed_fingers:
Here’s the relevant issue requesting it:
