v2.4.6
vaultwarden-proxy.dev.example.de {
reverse_proxy 10.110.180.110:30443 {
tls_insecure_skip_verify
tls example@example.de {
dns cloudflare example
output file /var/log/caddy/access-vaultwarden-proxy-dev-example-de.log
Also tried:
reverse_proxy / 10.110.180.110:30443 {
reverse_proxy https://10.110.180.110:30443 {
And:
tls
with the verify insecure
Ubuntu 20.04, systemd
3. What is my problem, error messages and/or full log output:
May 19 15:20:54 gateway-primary-zpx2e caddy[56074]: {"level":"debug","ts":1652973654.9613335,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"10.110.180.110:30443","duration":0.05179861,"request":{"remote_addr":"147.161.164.112:32251","proto":"HTTP/2.0","method":"GET","host":"vaultwarden-proxy.dev.example.de","uri":"/","headers":{"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"X-Forwarded-Proto":["https"],"Sec-Ch-Ua":["\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"101\", \"Google Chrome\";v=\"101\""],"Upgrade-Insecure-Requests":["1"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36"],"Sec-Fetch-Mode":["navigate"],"X-Forwarded-For":["147.161.164.112"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"macOS\""],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Site":["none"],"Accept-Encoding":["gzip, deflate, br"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"vaultwarden-proxy.dev.example.de"}},"error":"read tcp 10.110.180.157:40986->10.110.180.110:30443: read: connection reset by peer"}
May 19 15:20:54 gateway-primary-zpx2e caddy[56074]: {"level":"error","ts":1652973654.961822,"logger":"http.log.error.log8","msg":"read tcp 10.110.180.157:40986->10.110.180.110:30443: read: connection reset by peer","request":{"remote_addr":"147.161.164.112:32251","proto":"HTTP/2.0","method":"GET","host":"vaultwarden-proxy.dev.example.de","uri":"/","headers":{"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Site":["none"],"Accept-Encoding":["gzip, deflate, br"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"101\", \"Google Chrome\";v=\"101\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"macOS\""],"Upgrade-Insecure-Requests":["1"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"vaultwarden-proxy.dev.example.de"}},"duration":0.05234538,"status":502,"err_id":"p9i6mt9mz","err_trace":"reverseproxy.statusError (reverseproxy.go:886)"}
May 19 15:20:54 gateway-primary-zpx2e caddy[56074]: {"level":"error","ts":1652973654.9620607,"logger":"http.log.access.log8","msg":"handled request","request":{"remote_addr":"147.161.164.112:32251","proto":"HTTP/2.0","method":"GET","host":"vaultwarden-proxy.dev.example.de","uri":"/","headers":{"Accept-Encoding":["gzip, deflate, br"],"Cache-Control":["max-age=0"],"Sec-Ch-Ua":["\" Not A;Brand\";v=\"99\", \"Chromium\";v=\"101\", \"Google Chrome\";v=\"101\""],"Sec-Ch-Ua-Mobile":["?0"],"Sec-Ch-Ua-Platform":["\"macOS\""],"Upgrade-Insecure-Requests":["1"],"Accept":["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9"],"Sec-Fetch-Site":["none"],"User-Agent":["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/101.0.4951.64 Safari/537.36"],"Sec-Fetch-Mode":["navigate"],"Sec-Fetch-User":["?1"],"Sec-Fetch-Dest":["document"],"Accept-Language":["de-DE,de;q=0.9,en-US;q=0.8,en;q=0.7"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","proto_mutual":true,"server_name":"vaultwarden-proxy.dev.example.de"}},"common_log":"147.161.164.112 - - [19/May/2022:15:20:54 +0000] \"GET / HTTP/2.0\" 502 0","user_id":"","duration":0.05234538,"size":0,"status":502,"resp_headers":{"Server":["Caddy"]}}
4. What I already tried:
I am trying to use caddy as frontend gateway/loadbalancer for my services running in multiple k8s clusters. Because these are not publicly exposed caddy is running in a VM with a public IP and should reverse proxy these service domains to my cluster services.
This does already work great for some services running in docker and one cluster currently running traefik as ingress (with valid cloudflare/letsencrypt ssl certs). Because of unrelated reasons I want to use istio instead but I cannot get the same proxy working with the istio setup.
vaultwarden.example.de → caddy → traefik → vaultwarden work great, which makes me assume that i just have to redirect to the istio cluster instead of traefik.
But vaultwarden-proxy.dev.example.de returns an 502 error, because of connectio reset (see debug logs), which made me think that istio does not work.
When I set a local dns route to the istio host for vaultwarden-direct.dev.example.de the service is loading fine with valid certificates.
Well and now I am out of ideas whats wrong with my caddy config. The upstream (istio / 10.110.180.110:30443) works, since I am able to use it via a local dns route.
Any ideas would be very much appreciated
