1. Caddy version: Caddy 2
I’m running Caddy from Windows Server and attempting to use it as a Reverse Proxy to provide a secure connection to my Emby Server. Note: I already have my Domain and SSL Cert setup.
Windows Essentials Server where I have Caddy and Emby installed
Caddy run
Caddy start
N/A
email myemail@domain.com
jgcmedia.net {
reverse_proxy http://192.168.1.99:80
I’m trying to get Caddy 2 working with my Domain, SSL, Emby Server to provide a secure connection, however, I’m receiving errors when I run the “caddy run, start & stop” commands that I don’t fully understand…like I said, newbie. Also, I’m receiving this error when I try to access my domain:
This site can’t be reached
jgcmedia.net’s server IP address could not be found.</strong
Try:
Checking the connection
ERR_NAME_NOT_RESOLVED →
C:\Caddy>caddy run
2020/05/18 12:37:32.833 ←[34mINFO←[0m using adjacent Caddyfile
2020/05/18 12:37:32.841 ←[34mINFO←[0m admin admin endpoint started {“addres
s”: “tcp/localhost:2019”, “enforce_origin”: false, “origins”: [“localhost:2019”,
“[::1]:2019”, “127.0.0.1:2019”]}
2020/05/18 12:37:32.903 ←[34mINFO←[0m http server is listening only on the
HTTPS port but has no TLS connection policies; adding one to enable TLS {“server
_name”: “srv0”, “https_port”: 443}
2020/05/18 08:37:32 [INFO][cache:0xc00045d130] Started certificate maintenance r
outine
2020/05/18 12:37:32.904 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS r
edirects {“server_name”: “srv0”}
2020/05/18 12:37:32.908 ←[34mINFO←[0m tls cleaned up storage units
run: loading initial config: loading new config: http app module: start: tcp: li
stening on :443: listen tcp :443: bind: An attempt was made to access a socket i
n a way forbidden by its access permissions.
C:\Caddy>caddy start
2020/05/18 12:37:42.777 ←[34mINFO←[0m using adjacent Caddyfile
2020/05/18 12:37:42.785 ←[34mINFO←[0m admin admin endpoint started {“addres
2020/05/18 12:37:42.787 ←[34mINFO←[0m http server is listening only on the
2020/05/18 08:37:42 [INFO][cache:0xc0005bfae0] Started certificate maintenance r
outine
2020/05/18 12:37:42.789 ←[34mINFO←[0m http enabling automatic HTTP->HTTPS r
2020/05/18 12:37:42.793 ←[34mINFO←[0m tls cleaned up storage units
start: caddy process exited with error: exit status 1
C:\Caddy>caddy stop
2020/05/18 13:18:08.459 ←[33mWARN←[0m failed using API to stop instance
{“endpoint”: “http://localhost:2019/stop”, “error”: “performing request: Post "
http://localhost:2019/stop”: dial tcp [::1]:2019: connectex: No connection coul
d be made because the target machine actively refused it."}
stop: performing request: Post “http://localhost:2019/stop”: dial tcp [::1]:2019
: connectex: No connection could be made because the target machine actively ref
used it.
I’ve checked the IP address (WAN/Public) associated to my Domain - via Google Domain is accurate.
I’ve tested the Port Forwarding for 80 and 443 and they both tested successful.
My Windows Server has a static IP address. I’ve opened Ports 80 and 443 on my Windows Firewall.
Please let me know if you need any additional information. Thanks for any assistance.
