Caddy reverse proxy works fine for most things on my local network, but gives a 502 error for my PiHole.
2024/04/22 18:41:14.429 ERROR http.log.error dial tcp: lookup dns.direct: i/o timeout {"request": {"remote_ip": "192.168.86.26", "remote_port": "58600", "client_ip": "192.168.86.26", "proto": "HTTP/1.1", "method": "GET", "host": "dns.here", "uri": "/admin/cname_records.php", "headers": {"Cookie": [], "Connection": ["keep-alive"], "Upgrade-Insecure-Requests": ["1"], "User-Agent": ["Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36"], "Accept": ["text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7"], "Accept-Encoding": ["gzip, deflate"], "Accept-Language": ["en-US,en;q=0.9,he-IL;q=0.8,he;q=0.7"]}}, "duration": 3.003471011, "status": 502, "err_id": "7r391sk8i", "err_trace": "reverseproxy.statusError (reverseproxy.go:1267)"}
(piped through jq)
"request": {
"method": "GET",
"host": "dns.here",
"headers": {
"Cookie": [],
"Connection": [
"keep-alive"
"1"
"User-Agent": [
"Accept": [
"gzip, deflate"
"status": 502,
Installed stable version by following Debian/Ubuntu/Raspbian instructions
sudo apt update
sudo apt install caddy
Armbian 24.2.1 Jammy (Linux 6.6.16-current-meson64)
N/A
servers {
timeouts {
read_body 900s
read_header 900s
http://dns.here {
reverse_proxy dns.direct:80
Not links, but other network info:
dns.hereresolves to the Caddy hostdns.directresolves to the host running PiHole. I can resolve this DNS successfully from the Caddy host using dig:
caddy $ dig dns.direct
;; ANSWER SECTION:
dns.direct. 0 IN A 192.168.86.37
- If I convert the request from the Caddy log into a
curlcommand, I get the (expected) 302 response:
caddy $ curl -I -X GET \
'http://dns.direct/admin/cname_records.php' \
-H 'Connection: keep-alive' \
-H 'Upgrade-Insecure-Requests: 1' \
-H 'User-Agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/123.0.0.0 Safari/537.36' \
-H 'Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7' \
-H 'Accept-Encoding: gzip, deflate' \
-H 'Accept-Language: en-US,en;q=0.9,he-IL;q=0.8,he;q=0.7'
HTTP/1.1 302 Found
Expires: Thu, 19 Nov 1981 08:52:00 GMT
- Apparently that page expires in 1981…does Caddy’s reverse proxy implementation check page expiration date?
- That
302response takes ~15 seconds (for some reason), which lead me to think that Caddy might be terminating the request due to a timeout somewhere, since the Caddy error messages all show a"duration"of about 3 seconds. - Caddy’s Timeouts documentation states that the
read_bodyandread_headertimeout configurations default to “no timeout”, but I tried increasing them to 900 seconds anyway. Aftercaddy reload, that didn’t seem to affect the issue.
