v2.4.3
ubuntu 18 lts minimal , Google Cloud
jenkins.example.com {
reverse_proxy localhost:8080
2021/07/20 13:13:11.437 INFO using adjacent Caddyfile
2021/07/20 13:13:11.438 WARN input is not formatted with 'caddy fmt' {"adapter": "caddyfile", "file": "Caddyfile", "line": 1}
2021/07/20 13:13:11.439 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["localhost:2019", "[::1]:2019", "127.0.0.1:2019"]}
2021/07/20 13:13:11.439 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2021/07/20 13:13:11.439 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2021/07/20 13:13:11.439 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc00026d2d0"}
2021/07/20 13:13:11.440 INFO tls cleaning storage unit {"description": "FileStorage:/home/copi/.local/share/caddy"}
2021/07/20 13:13:11.441 INFO tls finished cleaning storage units
2021/07/20 13:13:11.440 INFO http enabling automatic TLS certificate management {"domains": ["jenkins.example.com"]}
2021/07/20 13:13:11.455 INFO autosaved config (load with --resume flag) {"file": "/home/copi/.config/caddy/autosave.json"}
2021/07/20 13:13:11.455 INFO serving initial configuration
cadd^C2021/07/20 13:14:12.335 INFO shutting down {"signal": "SIGINT"}
2021/07/20 13:14:12.335 WARN exiting; byeee!! 👋 {"signal": "SIGINT"}
2021/07/20 13:14:12.338 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc00026d2d0"}
2021/07/20 13:14:12.339 INFO admin stopped previous server {"address": "tcp/localhost:2019"}
2021/07/20 13:14:12.339 INFO shutdown complete {"signal": "SIGINT", "exit_code": 0}
and autosave.json
{"apps":{"http":{"servers":{"srv0":{"listen":[":443"],"routes":[{"handle":[{"handler":"subroute","routes":[{"handle":[{"handler":"reverse_proxy","upstreams":[{"dial":"localhost:8080"}]}]}]}],"match":[{"host":["jenkins.example.com"]}],"terminal":true}]}}}}}
i tried to change my Caddyfile config like this
it worked well, but when I tried to use my subdomain, it was not working, and got the error like this “The page isn’t redirecting properly” , why do I want to use my subdomain? because I want to use multi ports for this case for the next steps after I resolved this.
