I am having trouble routing KiwiBNC IRC bouncer webchat into a path on my site.
With the config seen below, I can access the webchat via the server IP and port 3001, plain http. I had to use this when I was still using Caddy v1 as well as I was unable to figure out a proper config after some changes in KiwiBNC routing code.
If I try to access it via https://mysite.org/kiwibnc/ I see in my dev tools console I get XHR 404 for https://mysite.org/kiwibnc_plugin.html
Any ideas?
Caddy v2 config:
mysite.org, www.mysite.org {
root * /var/www/mysite
route /kiwibnc/* {
uri strip_prefix /kiwibnc
reverse_proxy http://127.0.0.1:3001
The location of the 404’d file on disk is
/var/www/kiwibnc/src/extensions/webchat/kiwibnc_plugin.html
The source for KiwiBNC’s webchat routing:
KiwiBNC’s config.ini:
[listeners]
# Each listener accepts plain TCP connections, Websocket connections, and HTTP requests if enabled
bind = [
"0.0.0.0:3001",
# Websocket connections will only be allowed from these whitelisted websites
websocket_origins = [
"https://mysite.org",
"https://www.mysite.org",
"http://mysite.org:8080",
"http://my.ip.add.ress:3001",
[webserver]
# A static HTTP server. Handy for serving a web client such as Kiwi IRC
# If the webchat extension is enabled too, Kiwi IRC will automatically be downloaded
# and configured into the public_dir.
enabled = true
base_path = "/"
public_dir = "/var/www/kiwidata/kiwiirc"
[webchat]
# Extra configuration for the Kiwi web interface. The webchat extension must be loaded
# See https://github.com/kiwiirc/kiwiirc/wiki/Configuration-Options
# In exotic server setups or reverse proxies the correct BNC server may not be correctly detected.
# This server option should point to a listener address as configured above.
"startupOptions.websocket" = "wss://mysite.org/kiwibnc/ws/"
