The latest beta version: 2.0 beta 14
By the way, caddy -version command didn’t work:
[ERROR] first argument must be a subcommand; see 'caddy help'
- Ubuntu 18.04.4
- systemd 237
- Ruby 2.7.0
- Rails 6.0.2.1
- Puma 4.3.1
After copying all config files and creating caddy user/group:
sudo systemctl daemon-reload
sudo systemctl enable caddy
sudo systemctl start caddy
Description=Caddy Web Server
After=network.target
ExecStart=/usr/bin/caddy run --config /etc/caddy/Caddyfile --adapter caddyfile --resume --environ
ExecReload=/usr/bin/caddy reload --config /etc/caddy/Caddyfile --adapter caddyfile
d. My complete Caddyfile:
abc.jmstfv.com {
reverse_proxy localhost:3000
- Running Caddy without any directives (except the FQDN) works – I get a 200 response code and the empty response body
- Running Caddy with a
responddirective works – I get a 200 response and the response body - Running Caddy with a
reverse_proxydirective but with inactive backend (puma server) works as well – I get a 502 (Bad Gateway) response code (something that I’d expect) - Running Caddy with a
reverse_proxydirective and active backend (puma listening ontcp://0.0.0.0:3000) causes the infinite redirect
Requests never reach Puma server so no logs from there.
Output from grep "caddy" /var/log/syslog (timestamps & hostname not included):
caddy[893]: caddy.HomeDir=/var/lib/caddy
caddy[893]: caddy.AppDataDir=/var/lib/caddy/.local/share/caddy
caddy[893]: caddy.AppConfigDir=/var/lib/caddy/.config/caddy
caddy[893]: caddy.ConfigAutosavePath=/var/lib/caddy/.config/caddy/autosave.json
caddy[893]: runtime.GOOS=linux
caddy[893]: runtime.GOARCH=amd64
caddy[893]: runtime.Compiler=gc
caddy[893]: runtime.NumCPU=1
caddy[893]: runtime.GOMAXPROCS=1
caddy[893]: runtime.Version=go1.13.7
caddy[893]: os.Getwd=/
caddy[893]: LANG=C.UTF-8
caddy[893]: PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
caddy[893]: HOME=/var/lib/caddy
caddy[893]: LOGNAME=caddy
caddy[893]: USER=caddy
caddy[893]: INVOCATION_ID=bac5a082bf424d5aa981240272b2f5f0
caddy[893]: JOURNAL_STREAM=9:17536
caddy[893]: 2020/02/17 07:56:32.574#011#033[34mINFO#033[0m#011resuming from last configuration#011{"autosave_file": "/var/lib/caddy/.config/caddy/autosave.json"}
caddy[893]: 2020/02/17 07:56:32.636#011#033[34mINFO#033[0m#011admin#011admin endpoint started#011{"address": "localhost:2019", "enforce_origin": false, "origins": ["localhost:2019"]}
caddy[893]: 2020/02/17 07:56:32.636#011#033[34mINFO#033[0m#011http#011server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS#011{"server_name": "srv0", "https_port": 443}
caddy[893]: 2020/02/17 07:56:32.636#011#033[34mINFO#033[0m#011http#011enabling automatic HTTP->HTTPS redirects#011{"server_name": "srv0"}
caddy[893]: 2020/02/17 07:56:32.637#011#033[34mINFO#033[0m#011http#011enabling automatic TLS certificate management#011{"domains": ["abc.jmstfv.com"]}
caddy[893]: 2020/02/17 07:56:32 [INFO][cache:0xc0000945a0] Started certificate maintenance routine
caddy[893]: 2020/02/17 07:56:32.782#011#033[34mINFO#033[0m#011tls#011cleaned up storage units
caddy[893]: 2020/02/17 07:56:32.782#011#033[34mINFO#033[0m#011autosaved config#011{"file": "/var/lib/caddy/.config/caddy/autosave.json"}
caddy[893]: 2020/02/17 07:56:32.782#011#033[34mINFO#033[0m#011serving initial configuration
Infinite redirect:
abc.jmstfv.com {
reverse_proxy 0.0.0.0:3000
The same:
abc.jmstfv.com {
reverse_proxy / localhost:3000
You guessed it
abc.jmstfv.com
