I’m attempting to set up a Caddy 2 server in my WSL2 Debian environment in order to do some development work. Despite WSL2 not having systemd support, Caddy still works via the command line (e.g., $ caddy start, $ caddy stop, $ caddy reload, etc.).
When I try to run Caddy with my simple Caddyfile, I get a “connection refused” error.
2022/08/28 19:16:18.411 INFO using provided configuration {"config_file": "/home/night/Caddyfile", "config_adapter": ""}
2022/08/28 19:16:18.412 INFO using provided configuration {"config_file": "/home/night/Caddyfile", "config_adapter": ""}
reload: sending configuration to instance: performing request: Post "http://localhost:2019/load": dial tcp 127.0.0.1:2019: connect: connection refused
I’m new to both WSL2 and Caddy, so I really have no idea what to do
Honestly, I’m not too sure what to suggest. WSL does all kinds of funky stuff with networking.
But for context, localhost:2019 is Caddy’s admin endpoint. Using caddy reload attempts to push the new config to the admin endpoint. So if Caddy isn’t running, or the admin endpoint is turned off, then it won’t be possible to reload.
I feel like I’ve made a bit of progress. I’ve opened up ports 2019 and 443 in my Windows Firewall. I also moved my Caddyfile from my linux home directory to /etc/caddy/Caddyfile mainly because that’s where it really should go. My current error is now:
2022/08/28 20:44:39.219 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
2022/08/28 20:44:39.220 INFO using provided configuration {"config_file": "/etc/caddy/Caddyfile", "config_adapter": ""}
2022/08/28 20:44:39.221 INFO admin.api received request {"method": "POST", "host": "localhost:2019", "uri": "/load", "remote_ip": "127.0.0.1", "remote_port": "54460", "headers": {"Accept-Encoding":["gzip"],"Content-Length":["937"],"Content-Type":["application/json"],"Origin":["http://localhost:2019"],"User-Agent":["Go-http-client/1.1"]}}
2022/08/28 20:44:39.221 INFO admin admin endpoint started {"address": "tcp/localhost:2019", "enforce_origin": false, "origins": ["//localhost:2019", "//[::1]:2019", "//127.0.0.1:2019"]}
2022/08/28 20:44:39.221 INFO http server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS {"server_name": "srv0", "https_port": 443}
2022/08/28 20:44:39.221 INFO http enabling automatic HTTP->HTTPS redirects {"server_name": "srv0"}
2022/08/28 20:44:39.221 INFO tls.cache.maintenance started background certificate maintenance {"cache": "0xc000192c40"}
2022/08/28 20:44:39.222 INFO pki.ca.local root certificate is already trusted by system {"path": "storage:pki/authorities/local/root.crt"}
2022/08/28 20:44:39.222 INFO tls.cache.maintenance stopped background certificate maintenance {"cache": "0xc000192c40"}
2022/08/28 20:44:39.222 ERROR admin.api request error {"error": "loading config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: permission denied", "status_code": 400}
reload: sending configuration to instance: caddy responded with error: HTTP 400: {"error":"loading config: loading new config: http app module: start: tcp: listening on :80: listen tcp :80: bind: permission denied"}
2022/08/28 20:44:39.222 INFO admin stopped previous server {"address": "tcp/localhost:2019"}
Yeah, I noticed that and opened it, but the same error re: bind persists. A bit of research tells me this is because I’m not running caddy via systemd… is there a way to force it to accept low ports without systemd?
EDIT: I’m trying to get this to work because I’m pretty sure it’ll benefit others who would like to use caddy in a WSL2 development environment. Especially if it can be done pseudo-officially without resorting to systemd-genie. If that’s required, so be it, but it’d be cool to have a mostly out-of-the-box solution
Doesn’t seem to work, unfortunately. Same error.
I’m going to try installing systemd-genie later this week (when I have time) and see if that does the trick. I’ll post any new successes or failures here. Thanks for all your help so far!
Caddy works well on Windows directly, you could run two instances if all else fails, the one on Windows to reverse_proxy to the one inside WSL. Make sure to configure trusted_proxies private_ranges inside of your php_fastcgi config if you take this approach though, to make sure X-Forwarded-* headers still work.
