Caddy 2.9.1 -> 2.10.0 strange TLS issue
After an upgrade from 2.9.1 from 2.10.0 and the same Caddyfile, TLS errors are returned for specifc (not on-demand) hostnames (hpb.yolo.asia and web.cos.eu in Caddyfile) .
I found that adding tls force_automate to these two blocks resolved the issue and is back running as it was with v2.9.1.
Still, I wonder if this is the expected behavior in v2.10.0 or if it is a bug :slight_smile:
{"level":"debug","ts":1750475797.387161,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"hpb.yolo.asia"}
{"level":"debug","ts":1750475797.387172,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.yolo.asia"}
{"level":"debug","ts":1750475797.3871813,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.asia"}
{"level":"debug","ts":1750475797.3871906,"logger":"tls.handshake","msg":"no matching certificates and no custom selection logic","identifier":"*.*.*"}
{"level":"debug","ts":1750475797.3872213,"logger":"tls.handshake","msg":"no certificate matching TLS ClientHello","remote_ip":"1.46.12.74","remote_port":"64295","server_name":"hpb.yolo.asia","remote":"1.46.12.74:64295","identifier":"hpb.yolo.asia","cipher_suites":[4865,4866,4867,49195,49196,52393,49199,49200,52392,49171,49172,156,157,47,53],"cert_cache_fill":0.0003,"load_or_obtain_if_necessary":true,"on_demand":false}
{"level":"debug","ts":1750475797.3872805,"logger":"http.stdlib","msg":"http: TLS handshake error from 1.46.12.74:64295: no certificate available for 'hpb.yolo.asia'"}
Installed via apt get (cloudsmith repo)
Debian 12.11
systemctl start caddy
The one provided by the package
Type=notify
        admin 127.0.0.1:8888
        default_bind 127.0.0.1 [::1] 10.99.99.21 192.168.1.21
        grace_period 3s
                output file /var/log/caddy/caddy.log {
                        roll_size 250MiB
                        roll_keep_for 15d
                level ERROR
        email contact@cos.eu
        default_sni web.cos.eu
        servers {
                protocols h1 h2
        on_demand_tls {
                ask http://127.0.0.80/ask.php
(common) {
        # Return client IP
        @_client_ip {
                path /_client_ip
        respond @_client_ip "{client_ip}" 200 {
                close
        reverse_proxy http://127.0.0.80:80
(hsts) {
        header Strict-Transport-Security max-age=15752000;
# Specific entry for main host
web.cos.eu {
        import common
# Talk HPB for my.yolo.asia
hpb.yolo.asia {
        route /standalone-signaling/* {
                uri strip_prefix /standalone-signaling
                reverse_proxy http://127.0.0.1:8181
        import hsts
# Catch all routes for the rest of the domains
http:// {
        import common
# Match only host names and not ip-addresses:
https://*.*,
https://*.*.*,
https://*.*.*.*,
https://*.*.*.*.*,
https://*.*.*.*.*.* {
                on_demand
        import hsts
        import common
Thank you for your feedback!
I tried to find some info about this, the closest topic I can find that might be related is:
It’s a side-effect of this change
It was mentioned in the release notes
Oh okay I see (almost).
I was surprised that it did not request a certificate for these hosts let it be via the specific blocks for these hostnames or the on demande catch all, without having to add force_automate.
