matt
(Matt Holt)
September 20, 2022, 9:42pm
#1
We’re pleased to announce the release of Caddy 2.6 , which enables HTTP/3 by default, virtualizes the file system, emits events, increases performance of static files and FastCGI, and much, much more.
This is our biggest release since v2. Please upgrade, submit your feedback, and enjoy the new features and performance! Edit: v2.6.1 is out already. Use it instead!
Caddy 2.6
This is our biggest release since Caddy 2.
Caddy 2 changed the way the world serves the Web. By providing an online config API, automatic HTTPS, unlimited extensibility, certificate autom...
If your company uses or benefits from Caddy, we’d love to have you as a sponsor along with Stripe, Tailscale, ZeroSSL, and others:
DavidFW1960
(David Williams)
September 21, 2022, 2:26am
#6
So this doesn’t build with the lego-deprecated plugin
9peppe
(Giuseppe)
September 21, 2022, 5:07am
#7
Yeah… if only I had realized it was deprecated
(It’s there, I just didn’t read it.)
Error: adapting config using caddyfile: parsing caddyfile tokens for 'servers': /etc/caddy/Caddyfile:4 - Error during parsing: unrecognized protocol option 'experimental_http3'
Mohammed90
(Mohammed Al Sahaf)
September 21, 2022, 6:08am
#8
What do you mean? What are you seeing? Can you provide logs?
DavidFW1960
(David Williams)
September 21, 2022, 7:20am
#9
Try clicking the download button and selecting the lego-dns plugin. It say building forever before failing
Mohammed90
(Mohammed Al Sahaf)
September 21, 2022, 9:42am
#10
Gotcha. It’s a website issue, not with the release itself. I’ll check it out. Meanwhile, you can use xcaddy.
DavidFW1960
(David Williams)
September 21, 2022, 11:17am
#11
Thanks. I was going to try that but going away for a few days. I’ll try when I am home on Monday otherwise I am setup to use xcaddy…
DavidFW1960
(David Williams)
September 28, 2022, 3:48am
#12
Ok so success using xcaddy to build with plugin but the web download is still not building
matt
(Matt Holt)
September 28, 2022, 4:48am
#13
That plugin uses more memory to compile than our build server has available. (That’s why we deprecated it. Too heavy.) I might remove it from our download page.
DavidFW1960
(David Williams)
September 28, 2022, 6:08am
#14
2.6.0 was the first version it wouldn’t build on.
Anyway as lokn as we can use xcaddy…
matt
(Matt Holt)
September 28, 2022, 2:25pm
#15
It was probably cached before. Our build server has been quite busy so hasn’t had as much memory available lately.
system
(system)
Closed
January 18, 2023, 9:43pm
#17
This topic was automatically closed after 120 days. New replies are no longer allowed.
