Caddy 2.2 CORS setting in Caddyfile not working
CentOS 7
caddy run --config /etc/caddy/Caddyfile
None
(cors) {
        @origin{args.0} header Origin {args.0}
        header @origin{args.0} Access-Control-Allow-Origin "{args.0}"
myblog.com {
        root * /usr/share/file/my-blog
        header Access-Control-Allow-Methods "POST, GET, OPTIONS, PUT"
        header Access-Control-Allow-Headers "*"
        import cors https://login.myblog.com
        tls me@gmail.com
        encode zstd gzip
I submit a post request from https://myblog.com/login to https://login.myblog.com/auth/login which is an API.
I want to generate token from it.
However, in the browser console I got Origin https://myblog.com is not allowed by Access-Control-Allow-Origin.
But if I use Chrome extension Moesif CORS I can bypass this registration and everything works fine.
From my understanding I must messing up with the Cadyfile, could you please help me to find where I did wrong in the file?
Different format of the Caddyfile.
I think you have CORS backwards actually. Your login.myblog.com server is supposed to send CORS headers saying it allows being requested from myblog.com
Thank you for reply! You are right. I’m new to web development so I confused on CORS. Thank you for helping me out. :smiling_face_with_three_hearts:
