Running opencloud baremetal. Caddy as simple reverse proxy in front. Worked until the upgrade to 2.11.1:
OC login screen shows:
Failed to connect to server
Unexpected HTTP response: 400. Please check your connection and try again.
Reverting back to v2.11.0-beta.2 fixes the problem and it works again.
v2.11.1 h1:C7sQpsFOC5CH+31KqJc7EoOf8mXrOEkFyYd6GpIqm/s=
Downloaded binary runs as service
Debian GNU/Linux 11 (bullseye)
Ok - already found the culprit, problem is the Host Header change in 2.11.1:
Reverse proxy now automatically rewrites the Host header to the address of the upstream when the upstream is HTTPS
adding
header_up Host {host}
to the reverse_proxy declaration fixes it!
matt
(Matt Holt)
February 26, 2026, 5:13am
3
Yeah, sorry if that broke you. The previous default was insecure in some common configurations.
It’s probably best to explicitly pass-thru the client-facing hostname to the backend if that is what is needed. Although, that sounds like it would almost always surely be wrong … right?
