caddy v1.0.4
I run it with systemctl
LInux, systemd
/usr/local/bin/caddy "-agree=true" "-conf=/etc/caddy/Caddyfile" "-email=me@gmail.com"
not relevant
cache {
match_path /api/path
default_max_age 60m
path /tmp/caddy-cache
I am caching /api/path
for 1 hour and it is working great. However, there are certain instances that we need to return a non-cached value. I tried appending another query parameter (something that wasn’t in the cache) but it still returns the cached value.
e.g. the original url hit is https://example.com/api/path?email=bob
That gets cached for 1 hour. However, if I try to change the url by adding another query param then I still get the cached value:
https://example.com/api/path?email=bob&myparam=true
No error, I just expect it to not return a cached value.
Tried appending a new query parameter at the end. No dice.
