I was using Caddy 0.9.0 to proxy a server that returns a chunked HTTP response to simulate a push connection. This worked fine (clients would connect and receive the streaming data properly) until I upgraded to 0.9.3. With that version, Caddy waits for the response to terminate (and thus waits forever), with no way for me to actually start receiving data live.
Is there a new parameter that I can use to get the old behaviour back, or is this a bug?
There’s a lot of changes between those two versions. What’s your setup?
If you think it’s a bug, file an issue and follow the template thoroughly because if we can’t see the same behavior you’re describing it can’t be fixed. :-/ Thanks!
