Today I’m pleased to announce that Caddy 0.11 is released, which fixes a leaky file descriptor bug in the proxy middleware, and implements an optional telemetry client!
Check out our new stats page that shows some basic information about Caddy usage globally – it updates in near-real-time as updates come in – and you can look up your own instances, too.
Download Caddy 0.11 now! And don’t forget to enable telemetry if you want to view stats about your instance or participate in global Internet research.
I just updated it to take the env variable $CADDY_TELEMETRY. Can you test it out? Try export CADDY_TELEMETRY=on to enable it. You should see something in the process log when Caddy starts that it successfully emitted telemetry.
How can I access the collected telemetry data as a site owner? Is there an endpoint that provides this data that I can poll? The documentation lists insights as a benefit but fails to mention how to gain these insights
