In Caddy 1.0.3 I’ve been seeing “superfluous response.WriteHeader” and “wrote more than the declared Content-Length” warnings / errors output in the logs.
Additionally at times I’ve seen erroneous additional text at the bottom of responses, mostly during error responses. e.g.
503 Service Unavailable
Instead of just:
This has been seen in successful responses (200) too (at the bottom of HTML responses) - but not captured at the time.
I managed to track it down to when the http.cache plugin is used.
Whilst this could be two bugs - it’s likely related.
I’m noting it here for visibility of others before reporting this in the plugins repo.
Steps to reproduce
The version I tested with was downloaded from here: https://caddyserver.com/download/windows/amd64?plugins=http.cache&license=personal&telemetry=off
Caddyfile
http://localhost {
proxy / http://127.0.0.1
cache
log stdout
http:// {
status 418 /
log stdout
Console output
λ caddy -log stdout
2019/09/27 18:57:35 [INFO][cache:0xc000196230] Started certificate maintenance routine
Serving HTTP on port 80
http://localhost
http://
2019/09/27 18:57:35 [INFO] Serving http://localhost
127.0.0.1 - - [27/Sep/2019:18:57:38 +0100] "GET / HTTP/1.1" 418 17
2019/09/27 18:57:38 http: superfluous response.WriteHeader call from github.com/caddyserver/caddy/caddyhttp/httpserver.(*ResponseRecorder).WriteHeader (recorder.go:61)
2019/09/27 18:57:38 [Error] failed to write body: http: wrote more than the declared Content-Length
::1 - - [27/Sep/2019:18:57:38 +0100] "GET / HTTP/1.1" 418 17
2019/09/27 18:58:23 [INFO] SIGINT: Shutting down
2019/09/27 18:58:23 [INFO][cache:0xc000196230] Stopped certificate maintenance routine
Removing the cache line from the Caddyfile results in the errors / warnings not displaying.
