Caching `forward_auth` responses
I have this working Caddy config:
https://mysite {
  reverse_proxy backend-container:8000
  forward_auth * https://external-auth-service {
    uri /api/v2/auth
Which works correctly. I now, however, want to cache the responses from the auth service so I’m not hammering it with requests. I’ve added cache-handler to Caddy, but can’t work out how to cache responses from the auth service without caching responses from backend-container. Is this possible?
N/A
Dockerfile:
FROM caddy:2.9.1-builder AS builder
RUN xcaddy build \
      --with github.com/caddyserver/cache-handler
FROM caddy:2.9.1-alpine
I’m deploying this with Kamal, which is simply doing a docker run.
I worked it out and this is working nicely, adding a separate reverse proxy for the auth which I can then add caching to
  cache {
    stale 10m
https://mysite {
  forward_auth * https://auth.mysite {
    uri /api/v2/auth
  cache
  reverse_proxy https://external-auth-service {
    header_down -cache-control # Remove as marks as private to prevent caching
