Building and running caddy duckdns provider
I was using Caddy to expose one service and it worked well, now I wanted to expose a new service, using duckdns (I was using no-ip before but I didn’t find the plugging )
So after a lot of reading, I changed my compose file and I build caddy with duckdns plugging to get everything work, but since that, It doesn’t work at all, and I don’t have almos any log in the output, so now I’m not sure if building was succesfull (even if I didn’t have any error message)
Apparently no error messages
[+] Running 1/1
 ✔ Container caddy-caddy-1  Created        0.0s
Attaching to caddy-1
caddy-1 exited with code 0
Docker container running in a raspberry pi
sudo docker compose up -d
c. DockerFile file:
FROM caddy:builder AS builder
RUN xcaddy build \
    --with github.com/caddy-dns/duckdns
FROM caddy:builder
c. docker-compose file:
    build: .
      - "82:80"
      - "443:443/udp"
      - ./data/:/data/
      - ./config/:/config/
      - caddy_data:/data
      - caddy_config:/config
  caddy_data:
  caddy_config:
    email myhost@gmail.com
immich.myhost.duckdns.org {
         dns duckdns mytoken
    reverse_proxy 192.168.1.18:2283
traccar.myhost.duckdns.org {
        dns duckdns mytoken
    reverse_proxy 192.168.1.18:8082
You need to confirm the status of the service in Docker. Run docker compose logs caddy to find the logs.
Yes, it gives me nothing, is like container is restarting and cannot properly start.
So I guess my problem comes from my build docker image, but I cannot see what is wrong
