2.3.0
ubuntu VPS LTS latest
paste command here
paste full file contents here
# GLOBAL
# Optional email key for lets encrypt
# Optional staging lets encrypt for testing.
servers {
timeouts {
read_body 10s
read_header 10s
write 10s
idle 2m
max_header_size 16384
# SNIPPETS
(mustheaders) {
Strict-Transport-Security "max-age=31536000; includesubdomains; preload"
X-Frame-Options "SAMEORIGIN"
Referrer-Policy "same-origin"
X-Xss-Protection "1; mode=block"
Feature-Policy "accelerometer 'none'; autoplay 'none'; camera 'none'; encrypted-media 'none'; fullscreen 'self'; geolocation 'none'; gyroscope 'none'; magnetometer 'none'; microphone 'none'; midi 'none'; payment 'none'; picture-in-picture *; sync-xhr 'none'; usb 'none'"
Expect-CT "max-age=604800"
-Server
(compression) {
encode zstd gzip
(caching) {
@static {
file
path *.css *.js *.ico *.gif *.jpg *.jpeg *.png *.svg *.woff
handle @static {
header ?Cache-Control "public, max-age=5184000, must-revalidate"
header ?Cache-Control "no-cache, no-store, must-revalidate"
(security) {
# deny all access to these folders
@denied_folders path_regexp /(\.github|cache|bin|logs|backup|test)/.*$
respond @denied_folders "Access to this folder denied" 403
# deny running scripts inside core system folders
@denied_system_scripts path_regexp /(core|content|test|system|vendor)/.*\.(txt|xml|md|html|yaml|php|pl|py|cgi|twig|sh|bat|yml|js)$
respond @denied_system_scripts "Access running scripts denied" 403
# deny running scripts inside user folder
@denied_user_folder path_regexp /user/.*\.(txt|md|yaml|php|pl|py|cgi|twig|sh|bat|yml|js)$
respond @denied_user_folder "Access running scripts denied" 403
# deny access to specific files in the root folder
@denied_root_folder path_regexp /(index.php.*|wp-admin.php|wp-login.php|wp-config.php.*|xmlrpc.php|config.production.json|config.development.json|package.json|renovate.json|ghost.js|startup.js|\.editorconfig|\.eslintignore|\.eslintrc.json|\.gitattributes|\.gitignore|\.gitmodules|\.npmignore|Gruntfile.js|LICENSE|MigratorConfig.js|LICENSE.txt|composer.lock|composer.json|nginx.conf|web.config|htaccess.txt|\.htaccess)
respond @denied_root_folder "Access to the file denied" 403
# block bad crawlers
@badbots header User-Agent "AhrefsBot, DotBot, MauiBot, SemrushBot, PetalBot, MJ12bot, Seomoz, SEOstats, aesop_com_spiderman, alexibot, backweb, batchftp, bigfoot, blackwidow, blowfish, botalot, buddy, builtbottough, bullseye, cheesebot, chinaclaw, cosmos, crescent, curl, custo, da, diibot, disco, dittospyder, dragonfly, drip, easydl, ebingbong, erocrawler, exabot, eyenetie, filehound, flashget, flunky, frontpage, getright, getweb, go-ahead-got-it, gotit, grabnet, grafula, harvest, hloader, hmview, httplib, humanlinks, ilsebot, infonavirobot, infotekies, intelliseek, interget, iria, jennybot, jetcar, joc, justview, jyxobot, kenjin, keyword, larbin, leechftp, lexibot, lftp, libweb, likse, linkscan, linkwalker, lnspiderguy, lwp, magnet, mag-net, markwatch, memo, miixpc, mirror, missigua, moget, nameprotect, navroad, backdoorbot, nearsite, netants, netcraft, netmechanic, netspider, nextgensearchbot, attach, nicerspro, nimblecrawler, npbot, openfind, outfoxbot, pagegrabber, papa, pavuk, pcbrowser, pockey, propowerbot, prowebwalker, psbot, pump, queryn, recorder, realdownload, reaper, reget, true_robot, repomonkey, rma, internetseer, sitesnagger, siphon, slysearch, smartdownload, snake, snapbot, snoopy, sogou, spacebison, spankbot, spanner, sqworm, superbot, superhttp, surfbot, asterias, suzuran, szukacz, takeout, teleport, telesoft, thenomad, tighttwatbot, titan, urldispatcher, turingos, turnitinbot, *vacuum*, vci, voideye, libwww-perl, widow, wisenutbot, wwwoffle, xaldon, xenu, zeus, zyborg, anonymouse, *zip*, *mail*, *enhanc*, *fetch*, *auto*, *bandit*, *clip*, *copier*, *master*, *reaper*, *sauger*, *quester*, *whack*, *picker*, *catch*, *vampire*, *hari*, *offline*, *track*, *craftbot*, *download*, *extract*, *stripper*, *sucker*, *ninja*, *clshttp*, *webspider*, *leacher*, *collector*, *grabber*, *webpictures*, *seo*, *hole*, *copyright*, *check*"
respond @badbots "Access for bad crawlers denied" 403
(proxy) {
header_up X-Forwarded-For {remote}
header_up X-Real-IP {remote}
header_down X-Powered-By "the Holy Spirit"
header_down Server "CERN httpd"
(logs) {
output file /var/log/caddy/caddy.log
# STRIP WWW PREFIX
www.example.com {
redir * https://{http.request.host.labels.1}.{http.request.host.labels.0}{path} permanent
# WEBSITES
respond "Access denied" 403 {
close
example.com {
import mustheaders
import caching
import security
respond /healthcheck 200
reverse_proxy 127.0.0.1:2351 {
import proxy
import logs
Caddy stoped making logs in 18 April, no new logs there. However ghost CMS logs
Caddy do not block bad crawlers - Caddyfile config not working in this matter.
Changed user agent with Chrome extension.
