So I am trying to configure my network traffic to go trough a vps. Right now my setup is a follows.:
(local Servers ↔ local SBC(RPI4 with dietpi) running Caddy as a first reverse proxy (no https) to make all my server’s applications accessible on that SBC wich is also a wireguard peer/server)
-> Wireguard tunnel <-
(VPS wich is the other wireguard peer/server and is also running caddy as second reverse proxy with https to have access to the public web via port 80 and 443.)![]()
Now for this example I am running FileRun one a server and I want to serve this via my vps. Without https from my home to the vps and beyond works fine but when I try to serve it via my vps caddy reverse proxy(https enabled), Firefox and edge give me the following errors:
Blocked loading mixed active content...
and what follows is that Edge and Firefox doesn’t accept the https connection and only serves its via http while I got a valid certificate.
The weird thing is that when I remove one caddy reverse proxy(the one @myhome) in this line and I reverse proxy from my vps directly to the server’s application via his wireguard ip, everything works like a charm.
I have 1 kind of solution tho and that is to directly connect each server with my vps via wireguard but I want to centralise everything so that all the traffic goes via one gateaway and also so that I don’t have to open multiple ports just for vpn tunnel.
I hope anyone has maybe encountered this before or push me in the right direction?
Thanks in advance.
v2.6.4
sudo apt install -y debian-keyring debian-archive-keyring apt-transport-https
sudo apt update
sudo apt install caddy
SBC DietPi v8.15.2 RPi 4 Model B (aarch64)
VPS Debian GNU/Linux 11 (bullseye) x86_64
NA
NA
SBC:
:81 {
reverse_proxy 192.168.0.75:8080 {
VPS:
test.example.xyz {
reverse_proxy 10.76.8.1:81
