2.1.1
Linux - Manjaro KDE
Docker 19.03
docker run --rm -it \
--name caddytest \
-p 80:80 -p 443:443 \
-v $PWD/public:/usr/share/caddy/ \
-v $PWD/caddy/data:/data \
-v $PWD/caddy/Caddyfile:/etc/caddy/Caddyfile \
-v $PWD/caddy/tls:/tls caddy
N/A
http://pugs.localhost https://pugs.localhost {
#tls internal
tls /tls/pugs.localhost.pem /tls/pugs.localhost-key.pem
root * /usr/share/caddy
Support HTTP and HTTPS without redirect, but providing local cert for TLS when using HTTPS. Fails.
Not necessary for localhost
site address as Caddy would otherwise enable this implicitly for HTTPS, When explicit produces same problem:
tls internal
run: adapting config using caddyfile: hostname appears in more than one automation policy, making certificate management ambiguous: pugs.localhost
Supplying my own certificate with tls cert.pem key.pem
run: adapting config using caddyfile: server listening on [:80] is HTTP, but attempts to configure TLS connection policies
- Duplicating the inner config with the HTTPS block version having the tls line.
- Creating a snippet for the shared block content and using
import snippet_name
in each block.
Both of those work, just curious if it can all be managed in a single block instead of one for each protocol + snippet.
Also tried using handle protocol https {}
to wrap the tls
directive in conditionally, but this failed with error:
run: adapting config using caddyfile: parsing caddyfile tokens for 'handle': directive 'tls' is not ordered, so it cannot be used here
