Block access to certain paths when using Caddy as reverse proxy
1. Output of caddy version:
v2.6.2
Ubuntu 22.04
Systemd
Installed via APT
Paste command here.
gotify.******.com {
@notblacklisted {
not {
path */#/login
reverse_proxy @notblacklisted 10.0.0.20:8080
Paste your config here, replacing this text.
LEAVE DOMAIN NAMES INTACT.
Trying to block access to certain paths when using Caddy as a reverse proxy.
Gotify’s admin interface is mygotifydomain.com/#/login and I want to block/not proxy the path “/#/login” from the outside world. All other paths I want allowed to be accessed by the internet/proxied by Caddy.
I’ve tried following the “Blacklist” config here: V1: Block or allow certain paths to a backend, using Caddy proxy.
No Errors - Access to /#/login is still allowed
The part at and including # is called the “fragment” in the URI. That part is never sent to the server. That’s purely in the frontend. It’s not possible for the server to filter based on that.
Hi Francis, thanks for the response.
So is there no way I can restrict access using Caddy?
I guess the alternative is to go with a whitelist model and block all access and whitelist paths without that fragment?
Thanks
It’s impossible for the server to be aware of the fragment, because the browser never sends it to the server.
All Caddy will see is / and that’s it.
I’m not sure I understand what you’re trying to do. But it seems like you have a JS SPA which is a frontend router. With that setup, it’s not possible to block specific paths on the server, because it’s not the server that does the routing decisions.
You can probably block paths for your API though.
Fair enough, thank you for your help :slight_smile:
