Blank pages when using Docker
I ran the site with the following configuration and the page was blank after accessing via http, but it was accessible normally via https.
If I change the configuration to the following, I can access it normally again using http://pic.domain2.com.
pic.domain1.com, pic.domain2.com:80 {
	root * /www/wwwroot/pic.domain2.com/public
	php_fastcgi php-fpm:9000
To protect the site, I replaced the logs and the domain in the configuration file. But I don’t see any valid information from the logs
{"level":"info","ts":1686548029.5510778,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
{"level":"warn","ts":1686548029.5630326,"msg":"Caddyfile input is not formatted; run the 'caddy fmt' command to fix inconsistencies","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":3}
{"level":"info","ts":1686548029.5704167,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"info","ts":1686548029.5726993,"logger":"http","msg":"server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS","server_name":"srv0","https_port":443}
{"level":"warn","ts":1686548029.573492,"logger":"http","msg":"automatic HTTP->HTTPS redirects are disabled","server_name":"srv0"}
{"level":"warn","ts":1686548029.573579,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv1","http_port":80}
{"level":"info","ts":1686548029.5787704,"logger":"http","msg":"enabling HTTP/3 listener","addr":":443"}
{"level":"info","ts":1686548029.5789237,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
{"level":"info","ts":1686548029.5790515,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1686548029.5791352,"logger":"http.log","msg":"server running","name":"srv1","protocols":["h1","h2","h3"]}
{"level":"info","ts":1686548029.5792065,"logger":"http","msg":"enabling automatic TLS certificate management","domains":["tool.rainss.cn","pic.suger.live","pic.rainss.cn","api.rainss.cn","suger.live","rainss.cn"]}
{"level":"info","ts":1686548029.5850537,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000441730"}
{"level":"info","ts":1686548029.5852144,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
{"level":"info","ts":1686548029.5861866,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1686548029.5866659,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1686548029.5867283,"msg":"serving initial configuration"}
Docker 20.10.5+dfsg1
Debian GNU/Linux 11 (bullseye)
version: '3.2'
  webservice:
    image: caddy:latest
      - "443:443/udp"
      - /etc/localtime:/etc/localtime
      - /opt/caddy/Caddyfile:/etc/caddy/Caddyfile
      - /opt/caddy/config:/config
      - /opt/caddy/data:/data
      - /www/wwwroot:/www/wwwroot
    depends_on:
      - php-cgi
    restart: always
      - website
  php-cgi:
    container_name: php-fpm
    image: rainautos/php-fpm:8.1.15
    restart: always
      - website
  website:
    external: true
    email example@example.com
    auto_https disable_redirects
pic.domain1.com, pic.domain2.com {
What do you see when you make a request with curl -v? Turn on the debug global option, what do you see in Caddy’s logs after making a request?
I have turned on the global debug option, but no logs are generated after using curl -v.
*   Trying 82.xx.65.155:80...
* Connected to pic.xx.com(82.xx.65.155) port 80 (#0)
> GET / HTTP/1.1
> Host: pic.xx.com
> User-Agent: curl/7.74.0
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Mon, 12 Jun 2023 06:16:52 GMT
< Content-Length: 0
* Connection #0 to host pic.xx.com left intact
But my access to https has logs generated
  • Trying 82.xx.65.155:443…
  • Connected to pic.xx.com (82.xx.65.155) port 443 (#0)
  • schannel: disabled automatic use of client certificate
  • ALPN: offers http/1.1
  • ALPN: server accepted http/1.1
  • using HTTP/1.1
    > GET /1.php HTTP/1.1
    > Host: pic.xx.com
    > User-Agent: curl/8.0.1
    > Accept: /
  • schannel: remote party requests renegotiation
  • schannel: renegotiating SSL/TLS connection
  • schannel: SSL/TLS connection renegotiated
    < HTTP/1.1 200 OK
    < Alt-Svc: h3=“:443”; ma=2592000
    < Content-Type: text/html; charset=UTF-8
    < Server: Caddy
    < X-Powered-By: PHP/8.1.15
    < Date: Mon, 12 Jun 2023 06:24:13 GMT
    < Content-Length: 13
    test response* Connection #0 to host pic.xx.com left intact
{"level":"debug","ts":1686551239.0987267,"logger":"events","msg":"event","name":"tls_get_certificate","id":"47d0b9a8-3ca0-4411-a6a2-a25a6d68d28f","origin":"tls","data":{"client_hello":{"CipherSuites":[4866,4865,49196,49195,49200,49199,49188,49187,49192,49191,49162,49161,49172,49171,157,156,61,60,53,47],"ServerName":"pic.xx.com","SupportedCurves":[29,23,24],"SupportedPoints":null,"SignatureSchemes":[2052,2053,2054,1025,1281,513,1027,1283,515,514,1537,1539],"SupportedProtos":["http/1.1"],"SupportedVersions":[772,771,770,769],"Conn":{}}}}
{"level":"debug","ts":1686551239.0987973,"logger":"tls.handshake","msg":"choosing certificate","identifier":"pic.xx.com","num_choices":1}
{"level":"debug","ts":1686551239.0988088,"logger":"tls.handshake","msg":"default certificate selection results","identifier":"pic.xx.com","subjects":["pic.xx.com"],"managed":true,"issuer_key":"acme-v02.api.letsencrypt.org-directory","hash":"113c5a6fac908c0fa3d5c1c025c543d3c71129e886d3b4fb5b89c594dae942db"}
{"level":"debug","ts":1686551239.098814,"logger":"tls.handshake","msg":"matched certificate in cache","remote_ip":"111.121.108.222","remote_port":"33623","subjects":["pic.xx.com"],"managed":true,"expiration":1694248473,"hash":"113c5a6fac908c0fa3d5c1c025c543d3c71129e886d3b4fb5b89c594dae942db"}
{"level":"debug","ts":1686551239.1417654,"logger":"http.handlers.reverse_proxy","msg":"selected upstream","dial":"php-fpm:9000","total_upstreams":1}
{"level":"debug","ts":1686551239.1418664,"logger":"http.reverse_proxy.transport.fastcgi","msg":"roundtrip","request":{"remote_ip":"111.121.108.222","remote_port":"33623","proto":"HTTP/1.1","method":"GET","host":"pic.xx.com","uri":"/1.php","headers":{"User-Agent":["curl/8.0.1"],"Accept":["*/*"],"X-Forwarded-For":["111.121.108.222"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["pic.xx.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"pic.xx.com"}},"env":{"REMOTE_ADDR":"111.121.108.222","SERVER_NAME":"pic.xx.com","GATEWAY_INTERFACE":"CGI/1.1","REMOTE_IDENT":"","QUERY_STRING":"","REQUEST_URI":"/1.php","SERVER_PORT":"443","HTTP_X_FORWARDED_FOR":"111.121.108.222","HTTP_USER_AGENT":"curl/8.0.1","CONTENT_TYPE":"","REMOTE_HOST":"111.121.108.222","SERVER_PROTOCOL":"HTTP/1.1","CONTENT_LENGTH":"","REQUEST_METHOD":"GET","HTTP_X_FORWARDED_HOST":"pic.xx.com","HTTP_X_FORWARDED_PROTO":"https","AUTH_TYPE":"","HTTP_HOST":"pic.xx.com","SSL_PROTOCOL":"TLSv1.3","REQUEST_SCHEME":"https","DOCUMENT_ROOT":"/www/wwwroot/pic.suger.live/public","SCRIPT_FILENAME":"/www/wwwroot/pic.suger.live/public/1.php","HTTPS":"on","HTTP_ACCEPT":"*/*","PATH_INFO":"","REMOTE_PORT":"33623","SCRIPT_NAME":"/1.php","REMOTE_USER":"","SERVER_SOFTWARE":"Caddy/v2.6.4","SSL_CIPHER":"TLS_AES_128_GCM_SHA256","DOCUMENT_URI":"/1.php"},"dial":"php-fpm:9000","env":{"REMOTE_USER":"","SERVER_SOFTWARE":"Caddy/v2.6.4","SSL_CIPHER":"TLS_AES_128_GCM_SHA256","DOCUMENT_URI":"/1.php","GATEWAY_INTERFACE":"CGI/1.1","REMOTE_IDENT":"","QUERY_STRING":"","REMOTE_ADDR":"111.121.108.222","SERVER_NAME":"pic.xx.com","CONTENT_TYPE":"","REMOTE_HOST":"111.121.108.222","SERVER_PROTOCOL":"HTTP/1.1","REQUEST_URI":"/1.php","SERVER_PORT":"443","HTTP_X_FORWARDED_FOR":"111.121.108.222","HTTP_USER_AGENT":"curl/8.0.1","CONTENT_LENGTH":"","REQUEST_METHOD":"GET","HTTP_X_FORWARDED_HOST":"pic.xx.com","AUTH_TYPE":"","HTTP_HOST":"pic.xx.com","SSL_PROTOCOL":"TLSv1.3","HTTP_X_FORWARDED_PROTO":"https","REQUEST_SCHEME":"https","DOCUMENT_ROOT":"/www/wwwroot/pic.suger.live/public","SCRIPT_FILENAME":"/www/wwwroot/pic.suger.live/public/1.php","PATH_INFO":"","REMOTE_PORT":"33623","SCRIPT_NAME":"/1.php","HTTPS":"on","HTTP_ACCEPT":"*/*"},"request":{"remote_ip":"111.121.108.222","remote_port":"33623","proto":"HTTP/1.1","method":"GET","host":"pic.xx.com","uri":"/1.php","headers":{"User-Agent":["curl/8.0.1"],"Accept":["*/*"],"X-Forwarded-For":["111.121.108.222"],"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["pic.xx.com"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"pic.xx.com"}}}
{"level":"debug","ts":1686551239.1433005,"logger":"http.handlers.reverse_proxy","msg":"upstream roundtrip","upstream":"php-fpm:9000","duration":0.001473409,"request":{"remote_ip":"111.121.108.222","remote_port":"33623","proto":"HTTP/1.1","method":"GET","host":"pic.xx.com","uri":"/1.php","headers":{"X-Forwarded-Proto":["https"],"X-Forwarded-Host":["pic.xx.com"],"User-Agent":["curl/8.0.1"],"Accept":["*/*"],"X-Forwarded-For":["111.121.108.222"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"http/1.1","server_name":"pic.xx.com"}},"headers":{"Content-Type":["text/html; charset=UTF-8"],"X-Powered-By":["PHP/8.1.15"]},"status":200}
You disabled redirects, but didn’t instruct Caddy to actually do anything with HTTP requests, so all it can do is write an empty response.
What are you trying to do exactly?
I just want to use both http and https access without redirects, if I don’t use auto_https disable_redirects , how should I configure it? Or can I disable redirects for one site alone?
List both in your site addresses. E.g. http://example.com, example.com
Thanks for your answer, I’ll try it.
