Hi,
I’m new to Caddy so appreciate any assistance from the community!
I’m planning on introducing Caddy as a reverse proxy on my docker host for internal services. Before introducing LE and certs I wanted to try just using HTTP to ensure I familiar and simplify any debug.
I’ve got Caddy working successfully with HTTP to a whoami container, but any other services I attempt to configure and reach through the reverse proxy just return a blank browser.
My understanding is that Caddy will route to the containers by using the hostname configured within the caddy network (caddy_net in my deployment).
Caddy is running on a Debian 10 VM with docker running.
Docker engine 20.10.12
Docker compose version 1.29.2
I’m currently using docker-compose to deploy Caddy, whoami and heimdall (which is an example of a container experiencing the blank page loading)
caddy-docker-compose.yml
version: "3.7"
image: caddy
hostname: caddy
MY_DOMAIN
- ./data:/data
- ./config:/config
default:
external:
whoami-docker-compose.yml
version: "3.7"
whoami:
image: "containous/whoami"
container_name: "whoami"
hostname: "whoami"
default:
external:
Heimdall-docker-compose.yml
version: "3.7"
heimdall:
image: lscr.io/linuxserver/heimdall
container_name: heimdall2
hostname: heimdall
- PUID=1000
- PGID=1000
- TZ=Europe/London
- /home/matt/docker/heimdall:/config
- 4443:443
default:
external:
Env
MY_DOMAIN=arches.leymanit.co.uk
DOCKER_MY_NETWORK=caddy_net
http://whoami.{$MY_DOMAIN} {
reverse_proxy whoami:80
http://jackett.{MY_DOMAIN} {
reverse_proxy jackett:9117
http://dashboard.{MY_DOMAIN} {
reverse_proxy heimdall:80
The only container that works successfully is whoami. When I try to access any other container via HTTP, the browser displays a blank page. Curl indicates I get a 200OK but the content length is 0.
curl -v dashboard.arches.leymanit.co.uk
* Trying 192.168.0.101...
* TCP_NODELAY set
* Connected to dashboard.arches.leymanit.co.uk (192.168.0.101) port 80 (#0)
> GET / HTTP/1.1
> Host: dashboard.arches.leymanit.co.uk
> User-Agent: curl/7.64.1
< HTTP/1.1 200 OK
< Server: Caddy
< Date: Sun, 20 Feb 2022 21:07:46 GMT
< Content-Length: 0
* Connection #0 to host dashboard.arches.leymanit.co.uk left intact
* Closing connection 0
caddy | {"level":"info","ts":1645391588.6524658,"msg":"using provided configuration","config_file":"/etc/caddy/Caddyfile","config_adapter":"caddyfile"}
caddy | {"level":"warn","ts":1645391588.6540985,"msg":"input is not formatted with 'caddy fmt'","adapter":"caddyfile","file":"/etc/caddy/Caddyfile","line":2}
caddy | {"level":"info","ts":1645391588.6554434,"logger":"admin","msg":"admin endpoint started","address":"tcp/localhost:2019","enforce_origin":false,"origins":["[::1]:2019","127.0.0.1:2019","localhost:2019"]}
caddy | {"level":"info","ts":1645391588.6556406,"logger":"http","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
caddy | {"level":"info","ts":1645391588.656193,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
caddy | {"level":"info","ts":1645391588.6562622,"msg":"serving initial configuration"}
caddy | {"level":"info","ts":1645391588.6565893,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000535dc0"}
caddy | {"level":"info","ts":1645391588.656664,"logger":"tls","msg":"cleaning storage unit","description":"FileStorage:/data/caddy"}
caddy | {"level":"info","ts":1645391588.6567392,"logger":"tls","msg":"finished cleaning storage units"}
The destination containers can ping Caddy.
I’ve tried using the exposed port used by heimdall (880) within the Caddyfile.
I can wget from caddy towards heimdall:80, and index.html is downloaded.
/srv # wget heimdall:80
Connecting to heimdall:80 (172.28.0.2:80)
saving to 'index.html'
index.html 100% |***********************************************************************************************************************************| 147 0:00:00 ETA
'index.html' saved
The docker host can resolve the full external hostname (dashboard.arches.leymanit.co.uk) as this is served by local DNS.
I’ve looked at the other examples in the forum of blank pages and none seem to be applicable to my scenario.
Thanks in advance! Hope someone can point out what I’m missing here as I’m a little unclear! ![]()
