Best way to install and maintain Caddy with DNS module?
I need “best practice” approach to maintain the following Caddy binary.
I am using a custom Caddy with Duck DNS plugin using https://caddyserver.com/download. Everything is working, I am however wondering what is the best approach to maintain/update this custom Caddy. Right now, as I understand it, I would have to manually build Caddy each time there is an update?
I do not have any error. However, here’s my Caddyfile, with my DuckDNS API-key redacted out
my-jellyfin-server.duckdns.org {
        reverse_proxy 127.0.0.1:8096
                dns duckdns MYAPI-KEY
caddy version
Using the custom build image for DuckDNS (https://caddyserver.com/download). This image was then put in /usr/bin. The file caddy.service was created. So, using systemd approach.
Ubuntu Server LTS
cat /etc/*-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=24.04
DISTRIB_CODENAME=noble
DISTRIB_DESCRIPTION="Ubuntu 24.04.2 LTS"
PRETTY_NAME="Ubuntu 24.04.2 LTS"
NAME="Ubuntu"
VERSION_ID="24.04"
VERSION="24.04.2 LTS (Noble Numbat)"
VERSION_CODENAME=noble
ID=ubuntu
ID_LIKE=debian
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
UBUNTU_CODENAME=noble
LOGO=ubuntu-logo
Caddy is started at launch. Manually, that would be
sudo systemctl start caddy
/etc/systemd/system/caddy.service file
# caddy.service
# for your installation.
Type=notify
Caddyfile, with personal info redacted out (server name and DuckDNS API-KEY)
# domain name.
        # TLS DuckDNS
                dns duckdns MY-API
This is a Jellyfin configuration.
Well, I might have found my solution with caddy upgrade which should upgrade with the installed duckdns plug-in.
However, I ran the command and it seems stalled:
user@hostname:/etc/caddy$ sudo caddy upgrade
[sudo] password for user:
2025/04/07 13:25:46.380 INFO    this executable will be replaced        {"path": "/usr/bin/caddy"}
2025/04/07 13:25:46.380 INFO    requesting build        {"os": "linux", "arch": "amd64", "packages": ["github.com/caddy-dns/duckdns@v0.4.0"]}
We’re looking into build server issues lately.
caddy upgrade is just a shortcut for downloading the build from our website and then replacing the binary. In the meantime you can use xcaddy to easily build from source locally :+1:
ok, I’ll take a look at xcaddy and see what I need to do. Reading from the documentation, I would simply need to do something like (when vX.Y.Z is released)
xcaddy build vX.Y.Z --with github.com/caddy-dns/duckdns
or is the process a little bit more complex?
For the caddy upgrade solution, it’s simply a matter of waiting for the build server issues to be resolved or is it a feature that is phasing out because of those issues?
Thanks!
