Systemd unitfile for running caddy as a service is not specifying rules regarding the restart of the service. When the caddy server crashes or is killed, it is not auto restarted.
What is the best practice to keep caddy all the time up and running using systemd service?
Is there a recommended aproach to restart caddy server when the systemd service is alive but the caddy server is not responding?
Are there any examples, how for example a watchdog can be used to solve this issue?
no error messages
sudo apt install caddy
Debian GNU/Linux 11 (bullseye)
Linux gw 5.10.0-21-amd64 #1 SMP Debian 5.10.162-1 (2023-01-21) x86_64 GNU/Linux
no command
Type=notify
PrivateDevices=yes
www.mycompany.net {
root * /var/www
format json
output file /var/log/caddy/www.log
