Beginner having trouble setting up a reverse proxy
1. Output of caddy version:
2.6.1
I have Caddy installed on a Privileged Ubuntu container in my Proxmox server
Ubuntu 20.04 priveledged container
sudo caddy start
# domain name.
books2.jveronese.com {
        # root * /usr/share/caddy
        # file_server
        reverse_proxy 192.168.1.68:80
        # php_fastcgi localhost:9000
I have a few servers currently running on my homelab that I’d like to access without going through Cloudflare’s Zero Trust Tunnels for HTTPS. This is my current setup, but I get the error “too many redirects” when trying to access this via my web browser.
Output from “journalctl -u caddy --no-pager | less +G” gives me a bunch of lines with “~” followed by
-- Logs begin at Wed 2022-09-28 15:26:21 UTC, end at Wed 2022-09-28 15:26:30 UTC. --
-- No entries --
Tyring to use “curl -v” asks for a URL. Should I be using it on my domain or on the servers IP address?
This is what I get when trying it through the full URL on a different network. If that isn’t right please let me know.
C:\Users\jveronese>curl books2.jveronese.com -v
*   Trying xx.xx.xx.xx:80...
* Connected to books2.jveronese.com (xx.xx.xx.xx) port 80 (#0)
> GET / HTTP/1.1
> Host: books2.jveronese.com
> User-Agent: curl/7.83.1
< Connection: close
< Location: https://books2.jveronese.com/
< Server: Caddy
< Date: Wed, 28 Sep 2022 18:35:53 GMT
< Content-Length: 0
* Closing connection 0
Including ports, including http://, trying a separate reverse proxy for my Nextcloud server already over HTTPS (which gives a different error)
We need to see your logs regardless.
See the docs for how to look at your logs when running as a systemd service:
Also, try making a request with curl -v, and show us what you see.
Apologies, what I should have posted was that “journalctl -u caddy --no-pager | less +G” gives me a bunch of lines with “~” followed by
-- No entries --
> GET / HTTP/1.1
< Connection: close
< Server: Caddy
< Content-Length: 0
Is Caddy even running as a systemd service then? It seems like it’s not, if you’re not even seeing Caddy’s startup logs.
This is giving expected behaviour, i.e. a redirect from HTTP to HTTPS (with the Location header) because you didn’t specify the scheme, so curl assumes HTTP.
Instead, run this:
curl -v https://books2.jveronese.com
Actually, I think what’s happening is you’re telling Caddy to proxy to itself. So you get a redirect loop of HTTP->HTTPS redirects.
Make sure you have the right IP and port for your upstream app.
I have seen this on fresh VPS (virtual private server) wherein journalctl does not report any logs despite the systemd unit writing them. Usually a reboot fixes it. However, this begs the question whether you’re running Caddy using systemd or just running it directly in your shell.
This fixed it. I’ve been staring at this for too long lol. This does lead me to a second issue though. I also have NextCloud running (with it’s own SSL from Let’s Encrypt). However, it resolves to an error that says
Bad Request
Your browser sent a request that this server could not understand.
You're speaking plain HTTP to an SSL-enabled server port. Instead use HTTPS scheme to access this URL.
Is there somthing I need to enable in my config to let the HTTPS talk to it? Or should I just disable HTTPS on NextCloud? Would Caddy take care of the HTTPS portion on its own?
My Caddy file
nimbus.jveronese.com {
        reverse_proxy 192.168.1.226:443
It seems to be running. If I look at systemctl it shows green and active. Even after a reboot the logs still show the same thing.
Yes, that’s what Caddy excels at. Caddy’s most famous feature is Automatic HTTPS.
See this article, which explains how the networking works when you’re running Caddy in a home network:
Got it, with SSL disabled on the Cloudflare end everything works and it looks like Caddy is giving me the green lock, so I think we’re all good.
Thanks!
