hi all,
iam using caddy2 as reverse Proxy.
everytrhing is workin like a charm.
i do have a Kibana (ELK-Stack) behind the reverse Proxy.
i want to enable basicauth against the reverse proxy, and if authentication is successfull it should proxy to kibana.
The Problem iam having:
caddy forwards the authentication token to kibana, but kibana has its own authentication and therefore it tells me Unauthorized since the basicauth user is only available to caddy. is there a way to not forward the authentication header to the backend?
At the end of the Day i want to have “dual Auth” 1st BasicAuth against reverse Proxy
2nd: Normal Auth from Kibana.
config:
kib.hasinet.at {
@notLocal {
not remote_ip 172.16.0.0/16
basicauth @notLocal {
keim JDJhJDEwJHV2akerSnhyRMNOcHFLUzgyQUxPZS5sd01XN2ljYW16RVNhVU1DZGYzT3pBdEVVTmNuN1Au
reverse_proxy * {
to 172.16.0.2:5601
header_up Access-Control-Allow-Origin *
header_up Access-Control-Allow-Credentials true
header_up Access-Control-Allow-Headers Cache-Control,Content-Type
read_buffer 8192
so far,
axp
