Basicauth + handle_errors issue persists
v2.4.6
systemd
Arch, systemd
N/A
N/A
    admin off
    email name@mysite.com
    key_type rsa4096
(standards) {
    encode zstd gzip
        Referrer-Policy "same-origin"
        Cache-Control "max-age=31536000"
        X-Frame-Options "deny"
        protocols tls1.2 tls1.3
mysite.com, www.mysite.com {
    root * /var/www/mysite
    import standards
    basicauth /secret/* {
	foo (hashed-password-here)
    handle_errors {
	redir https://mysite.com
Others have posted about the “handle_errors” directive conflicting with the “basicauth” directive since 2019, and to the credit of the Caddy team, a fix was implemented, but I’m still experiencing the issue on a brand new Arch server with the latest Caddy release, adhering to the official Caddy documentation.
curl -I https://mysite.com/secret responds:
HTTP/2 302
server: Caddy
www-authenticate: Basic realm="restricted"
In a browser, mysite.com/secret redirects to mysite.com
If I remove the handle_errors directive, it responds:
HTTP/2 401
server: Caddy
In a browser, mysite.com/secret now works.
You’ll need to use matchers in your handle_errors to write the 401 status code again if that’s the error that was emitted.
So I guess the solution is this?
    import standards
    handle_errors {
        @nope expression `{http.error.status_code} == 404`
            handle @nope {
	            respond {http.error.status_code}
If this is such a common, known issue, shouldn’t the basicauth directive documentation page make it clear that it conflicts with the handle_errors directive, and that this is the recommended implementation?
You’re right, we should improve the docs on this. If you want to take a crack at it, the docs are here: GitHub - caddyserver/website: The Caddy website
Your solution looks okay, I guess it’ll just fall through and write the original error if you didn’t specifically handle it. And if you only care about redirecting 404s, then that should be fine.
