version 2.3.0
Raspberry Pi, Docker 19.03.13
Caddy I administrate in Portainer.
caddy reload
"AppArmorProfile": "",
"Args": [
"run",
"--config",
"/config/Caddyfile",
"--adapter",
"caddyfile"
"Config": {
"AttachStderr": false,
"AttachStdin": false,
"AttachStdout": false,
"Cmd": [
"caddy",
"run",
"--config",
"--adapter",
"caddyfile"
"Domainname": "",
"Entrypoint": null,
"Env": [
"PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"CADDY_VERSION=v2.3.0",
"XDG_CONFIG_HOME=/config",
"XDG_DATA_HOME=/data"
"ExposedPorts": {
"2019/tcp": {},
"443/tcp": {},
"80/tcp": {}
"Hostname": "d70063c8960d",
"Image": "caddy:latest",
"Labels": {
"org.opencontainers.image.description": "a powerful, enterprise-ready, open source web server with automatic HTTPS written in Go",
"org.opencontainers.image.documentation": "https://caddyserver.com/docs",
"org.opencontainers.image.licenses": "Apache-2.0",
"org.opencontainers.image.source": "https://github.com/caddyserver/caddy-docker",
"org.opencontainers.image.title": "Caddy",
"org.opencontainers.image.url": "https://caddyserver.com",
"org.opencontainers.image.vendor": "Light Code Labs",
"org.opencontainers.image.version": "v2.3.0"
"OnBuild": null,
"OpenStdin": false,
"StdinOnce": false,
"Tty": false,
"User": "",
"Volumes": {
"/config": {},
"/data": {},
"/srv": {}
"WorkingDir": "/srv"
"Created": "2021-04-04T11:33:47.600143609Z",
"Driver": "overlay2",
"ExecIDs": [
"088f3b6853688b75d7a79d4527e4a52eb91b00b866708fe5500f6f23514e9c7d",
"aaf42a433b8f6f6ea5f9aed94c59d8963fc698b23622d18e522f3ad6ec44a350"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/8edbba660571ab1622059aba3a4c1ca9998250a5b7f72a836fa466ec8246d5db-init/diff:/var/lib/docker/overlay2/0965fe3fdd29232a3461f35e742b85b12a7132cb331113b721884f25abde2f7f/diff:/var/lib/docker/overlay2/7828abb91200ff5278f2eced68dcfaa6a99ab5c8b4b16bb4663b315ae0842b13/diff:/var/lib/docker/overlay2/ea1fed0ef2acf04648c652f871daba758c5ab342f74547c810c39807a65b1748/diff:/var/lib/docker/overlay2/08f14ad14bd81543eb3e36bce4cb424c5e65a2ffb1f4bb58a6d8481b26acda98/diff:/var/lib/docker/overlay2/f46e2814a7bb3f699f6bb5242d637cd4251415b258b96bd734922c4f83af8487/diff",
"MergedDir": "/var/lib/docker/overlay2/8edbba660571ab1622059aba3a4c1ca9998250a5b7f72a836fa466ec8246d5db/merged",
"UpperDir": "/var/lib/docker/overlay2/8edbba660571ab1622059aba3a4c1ca9998250a5b7f72a836fa466ec8246d5db/diff",
"WorkDir": "/var/lib/docker/overlay2/8edbba660571ab1622059aba3a4c1ca9998250a5b7f72a836fa466ec8246d5db/work"
"Name": "overlay2"
"HostConfig": {
"AutoRemove": false,
"Binds": [
"/home/pi/docker/caddy-prod-01/srv:/srv",
"/home/pi/docker/caddy-prod-01/data:/data",
"/home/pi/docker/caddy-prod-01/config:/config"
"BlkioDeviceReadBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceWriteIOps": null,
"BlkioWeight": 0,
"BlkioWeightDevice": [],
"CapAdd": [
"AUDIT_WRITE",
"CHOWN",
"DAC_OVERRIDE",
"FOWNER",
"FSETID",
"KILL",
"MKNOD",
"NET_BIND_SERVICE",
"NET_RAW",
"SETFCAP",
"SETGID",
"SETPCAP",
"SETUID",
"SYS_CHROOT"
"CapDrop": [
"AUDIT_CONTROL",
"BLOCK_SUSPEND",
"DAC_READ_SEARCH",
"IPC_LOCK",
"IPC_OWNER",
"LEASE",
"LINUX_IMMUTABLE",
"MAC_ADMIN",
"MAC_OVERRIDE",
"NET_ADMIN",
"NET_BROADCAST",
"SYSLOG",
"SYS_ADMIN",
"SYS_BOOT",
"SYS_MODULE",
"SYS_NICE",
"SYS_PACCT",
"SYS_PTRACE",
"SYS_RAWIO",
"SYS_RESOURCE",
"SYS_TIME",
"SYS_TTY_CONFIG",
"WAKE_ALARM"
"Capabilities": null,
"Cgroup": "",
"CgroupParent": "",
"ConsoleSize": [
0,
0
"ContainerIDFile": "",
"CpuCount": 0,
"CpuPercent": 0,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpuShares": 0,
"CpusetCpus": "",
"CpusetMems": "",
"DeviceCgroupRules": null,
"DeviceRequests": null,
"Devices": [],
"Dns": [],
"DnsOptions": [],
"DnsSearch": [],
"ExtraHosts": [],
"GroupAdd": null,
"IOMaximumBandwidth": 0,
"IOMaximumIOps": 0,
"IpcMode": "private",
"Isolation": "",
"KernelMemory": 0,
"KernelMemoryTCP": 0,
"Links": null,
"LogConfig": {
"Config": {},
"Type": "json-file"
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"Memory": 0,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"NanoCpus": 0,
"NetworkMode": "host",
"OomKillDisable": null,
"OomScoreAdj": 0,
"PidMode": "",
"PidsLimit": null,
"PortBindings": {},
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"ReadonlyRootfs": false,
"RestartPolicy": {
"MaximumRetryCount": 0,
"Name": "no"
"Runtime": "runc",
"SecurityOpt": null,
"ShmSize": 67108864,
"UTSMode": "",
"Ulimits": null,
"UsernsMode": "",
"VolumeDriver": "",
"VolumesFrom": null
"HostnamePath": "/var/lib/docker/containers/cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4/hostname",
"HostsPath": "/var/lib/docker/containers/cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4/hosts",
"Id": "cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4",
"Image": "sha256:42db38da968682707e6cf0fabb16f93770388907d8a208fca0db74cae3183ba2",
"LogPath": "/var/lib/docker/containers/cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4/cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4-json.log",
"MountLabel": "",
"Mounts": [
"Destination": "/srv",
"Mode": "",
"Propagation": "rprivate",
"RW": true,
"Source": "/home/pi/docker/caddy-prod-01/srv",
"Type": "bind"
"Destination": "/data",
"Mode": "",
"RW": true,
"Source": "/home/pi/docker/caddy-prod-01/data",
"Type": "bind"
"Destination": "/config",
"Mode": "",
"RW": true,
"Source": "/home/pi/docker/caddy-prod-01/config",
"Type": "bind"
"Name": "/caddy_test_01",
"NetworkSettings": {
"Bridge": "",
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"HairpinMode": false,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"MacAddress": "",
"Networks": {
"host": {
"Aliases": null,
"DriverOpts": null,
"EndpointID": "73e53b9219ee8b148f033ba26b0fd8b418c6ef76e473417ed54885be239f2e59",
"Gateway": "",
"IPAMConfig": {},
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"Links": null,
"MacAddress": "",
"NetworkID": "5c689c02a96ba7da1d82b8150074279020e3fa92fac352dcb5ca331e01169eb8"
"Ports": {},
"SandboxID": "b78cb93b04f2feb1a5cccf6751a75ffb56c471514147610021330704742aadd0",
"SandboxKey": "/var/run/docker/netns/default",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null
"Path": "caddy",
"Platform": "linux",
"Portainer": {
"ResourceControl": {
"Id": 43,
"ResourceId": "cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4",
"SubResourceIds": [],
"Type": 1,
"UserAccesses": [],
"TeamAccesses": [],
"Public": false,
"AdministratorsOnly": true,
"System": false
"ProcessLabel": "",
"ResolvConfPath": "/var/lib/docker/containers/cb34068c7a8e225a2de9e433bcd8bc85a7cef56c50555173d0e5e69d4adc86f4/resolv.conf",
"RestartCount": 0,
"State": {
"Dead": false,
"Error": "",
"ExitCode": 0,
"FinishedAt": "2021-04-14T17:01:55.083064722Z",
"OOMKilled": false,
"Paused": false,
"Pid": 26214,
"Restarting": false,
"Running": true,
"StartedAt": "2021-04-14T17:01:56.149599327Z",
"Status": "running"
rr11.duckdns.org {
reverse_proxy /ui/* 192.168.2.61:1880
192.168.2.62 {
root * /srv
# Nodered Dashboard under /ui/
basicauth / { maggi JDJhJDE0JE93ek5Td2RCc3JhLzhVZ1RhUDJmMmVFL3BWQi5hTFd2cnBJOHJWQTJFbzV2d0pDUXhUaEtL }
# lägga till portainer där inkommande är /portainer/
handle /portainer/* {
uri replace /portainer/ /
reverse_proxy 192.168.2.62:9000
# leverera html
3. The problem Iâm having:
basicauth gives a error message, se below. Everything except basicauth is working just fine.
/config # caddy reload
2021/04/16 08:29:17.995 INFO using adjacent Caddyfile
reload: sending configuration to instance: caddy responded with error: HTTP 400: {âerrorâ:âloading config: loading new config: loading http app module: provision http: server srv0: setting up route handlers: route 1: loading handler modules: position 0: loading module âsubrouteâ: provision http.handlers.subroute: setting up subroutes: route 1: loading handler modules: position 0: loading module âauthenticationâ: provision http.handlers.authentication: loading authentication providers: module name âhttp_basicâ: provision http.authentication.providers.http_basic: base64-decoding password: illegal base64 data at input byte 4â}
I tried:
- changing the path in after basicauth to / or * or /ui/ - all give the same error
- copied the exact texts and example from example page on basicauth, still the same error
- Recreate the caddy container couple of times
