Official Alpine Docker image/container from Docker Hub.
b. Service/unit/compose file:
image: caddy:alpine
labels:
- com.centurylinklabs.watchtower.enable=true
- "4443:443"
- "8080:80"
- redacted
- ./caddy/data:/data
- ./caddy/config:/config
- /mnt/media/websites:/www/websites:ro
env_file: ./envs/common.env
c. My complete Caddyfile or JSON config:
http:// {
basicauth /* {
username password
handle_errors {
rewrite * /{http.error.status_code}
reverse_proxy https://http.cat
root / /www/websites/
With the above Caddyfile, there is no prompt for basic auth. You’re immediately displayed the 401 status page (in this case that is https://http.cat/401). The handle_errors solution is from this github issue.
N/A
Commenting or removing
handle_errors {
resolves the issue, so there seems to be an issue with order of operations preventing the auth prompt from ever appearing.
I’m open to either the order of operations being changed at the source or a different solution to error handling that would resolve this.
