basicauth /home/m/Downloads Bob hiccup
browse
root /home/m/Downloads
gzip
log access.log
When I access localhost:3333 I would expect a login prompt asking for the name and password, but I can just access the folder without a login. Am I doing anything wrong?
And can I use root as the path for basicauth? So that I get a login prompt on the start directory? Something linke
With your basicauth config you are only protecting localhost:3333/home/m/Downloads, if you want to protect localhost:3333 you need to change /home/m/Downloads to /.
Is it possible to set multiple basicauth for different subfolders or subsubfolders to have something like a simple account management?
And is there a template or already implemented function to give people readonly and/or upload rights to add new files to the file server through the template site (like a upload button or something like that)?
Basic auth is very simple. Hence the name, basic. Although we may upgrade its capabilities slightly in the future, the fundamental spec of basic authentication is still very basic.
