): 2.1.1
Caddy is running inside docker with PHP 7.4 FPM side by side.
- Docker (Base image PHP 7.4 FPM alpine. Installation of Caddy is based on the original Docker Caddy image)
- Supervisor.d
Supervisor.d command to start the caddy process:
supervisord.conf
[supervisord]
nodaemon=true
[program:caddy]
command=caddy run --config /etc/caddy/Caddyfile --adapter caddyfile
stdout_logfile=/dev/stdout
stdout_logfile_maxbytes=0
stderr_logfile=/dev/stderr
stderr_logfile_maxbytes=0
[program:php-fpm]
command=php-fpm
example.myhiddendomain.com {
root * /site/public
try_files {path} /index.php?{query}
encode zstd gzip
php_fastcgi unix//run/php-fpm.sock
@exceptstripe not path /stripe/webhook /stripe/payment/*
basicauth @exceptstripe {
# hash = password
user JDJhJDEwJFgzR3EyVXRyMFRENmRCQmFTYUl2Yk9IQmtzVDI5VjZuMm1FLmVhck5MRlA1NWFObzJtYzll
Strict-Transport-Security max-age=30758400;
Referrer-Policy same-origin
X-Frame-Options DENY
# Access logging in the combined format
output file /var/log/access.log {
roll_size 50MiB
roll_keep 14
roll_keep_for 336h # 14 days
format json
output stdout
The except directive @exceptstripe
is not being applied to routes like https://example.myhiddendomain.com/stripe/webhook
and https://example.myhiddendomain.com/stripe/payment/foo
All routes are secured via basic auth, so I’m not able to make an exception for the above uri’s.
The routes may not have not be secured with the Basicauth directive as the Stripe server needs to talk to the server.
There are no error messages. The error is that the Basicauth
dialog is prompted.
I already tried the longer syntax which didn’t work as well.
Like:
@exceptstripe {
not {
I did’t try the expression syntax because I suppose there is some problem with my understanding of how the not directive is working.
I would gladly appreciate any feedback or hints.
Thanks!
