Basic reverse proxy on Cloudflare
Trying to set up jellyfin as a reverse proxy, but something is misconfigured…
text  error  warn  system  array  login
{"level":"info","ts":1741629074.2059858,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1741629074.2061577,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1741629074.2061615,"msg":"serving initial configuration"}
{"level":"info","ts":1741629074.2066343,"logger":"tls","msg":"cleaning storage unit","storage":"FileStorage:/data/caddy"}
{"level":"info","ts":1741629074.2068803,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1741629200.583151,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1741629200.5831907,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1741629200.5831974,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1741629200.5833302,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1741629200.5833359,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1741629200.9283364,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1741629200.9286826,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1741629200.9290082,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"warn","ts":1741629200.929058,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1741629200.929166,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004e6500"}
{"level":"warn","ts":1741629200.9291723,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1741629200.9291751,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1741629200.9291775,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1741629200.9292643,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1741629200.929268,"msg":"serving initial configuration"}
{"level":"info","ts":1741629200.9295766,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"90cb01b0-ac44-49fa-9431-425e82e233e5","try_again":1741715600.929576,"try_again_in":86399.999999835}
{"level":"info","ts":1741629200.929609,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1741629508.0431206,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1741629508.043344,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1741629508.0433555,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1741629508.0436661,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1741629508.0436728,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1741629508.3900383,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1741629508.3906012,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1741629508.390992,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"warn","ts":1741629508.3910627,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1741629508.3911226,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc000453f00"}
{"level":"warn","ts":1741629508.3911676,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1741629508.3911712,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1741629508.3911726,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1741629508.3912613,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1741629508.3912659,"msg":"serving initial configuration"}
{"level":"info","ts":1741629508.391621,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"90cb01b0-ac44-49fa-9431-425e82e233e5","try_again":1741715908.39162,"try_again_in":86399.999999836}
{"level":"info","ts":1741629508.3916545,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1741629651.8556306,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1741629651.855658,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1741629651.855666,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1741629651.855951,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1741629651.855958,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1741629652.1945386,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1741629652.1950908,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1741629652.195425,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"warn","ts":1741629652.195475,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1741629652.1955307,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004a9c80"}
{"level":"warn","ts":1741629652.195582,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1741629652.1955853,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1741629652.1955864,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1741629652.1956918,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1741629652.1956968,"msg":"serving initial configuration"}
{"level":"info","ts":1741629652.195983,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"90cb01b0-ac44-49fa-9431-425e82e233e5","try_again":1741716052.195982,"try_again_in":86399.999999829}
{"level":"info","ts":1741629652.1960096,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1741629684.2719834,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1741629684.2720327,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1741629684.2720392,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1741629684.272154,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1741629684.2721608,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1741629684.623285,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1741629684.623729,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1741629684.624212,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"warn","ts":1741629684.6242752,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1741629684.6243343,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc00050f900"}
{"level":"warn","ts":1741629684.6243966,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1741629684.6244001,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1741629684.6244013,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1741629684.6244905,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1741629684.6244948,"msg":"serving initial configuration"}
{"level":"info","ts":1741629684.6248121,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"90cb01b0-ac44-49fa-9431-425e82e233e5","try_again":1741716084.6248112,"try_again_in":86399.999999852}
{"level":"info","ts":1741629684.624838,"logger":"tls","msg":"finished cleaning storage units"}
{"level":"info","ts":1741629772.7915711,"msg":"shutting down apps, then terminating","signal":"SIGTERM"}
{"level":"warn","ts":1741629772.7915912,"msg":"exiting; byeee!! 👋","signal":"SIGTERM"}
{"level":"info","ts":1741629772.7916124,"logger":"http","msg":"servers shutting down with eternal grace period"}
{"level":"info","ts":1741629772.7917314,"logger":"admin","msg":"stopped previous server","address":"localhost:2019"}
{"level":"info","ts":1741629772.7917361,"msg":"shutdown complete","signal":"SIGTERM","exit_code":0}
{"level":"info","ts":1741629773.1341603,"msg":"using config from file","file":"/etc/caddy/Caddyfile"}
{"level":"info","ts":1741629773.1345572,"msg":"adapted config to JSON","adapter":"caddyfile"}
{"level":"info","ts":1741629773.1349494,"logger":"admin","msg":"admin endpoint started","address":"localhost:2019","enforce_origin":false,"origins":["//localhost:2019","//[::1]:2019","//127.0.0.1:2019"]}
{"level":"warn","ts":1741629773.1350017,"logger":"http.auto_https","msg":"server is listening only on the HTTP port, so no automatic HTTPS will be applied to this server","server_name":"srv0","http_port":80}
{"level":"info","ts":1741629773.1350706,"logger":"tls.cache.maintenance","msg":"started background certificate maintenance","cache":"0xc0004f8b80"}
{"level":"warn","ts":1741629773.135104,"logger":"http","msg":"HTTP/2 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"warn","ts":1741629773.1351085,"logger":"http","msg":"HTTP/3 skipped because it requires TLS","network":"tcp","addr":":80"}
{"level":"info","ts":1741629773.1351097,"logger":"http.log","msg":"server running","name":"srv0","protocols":["h1","h2","h3"]}
{"level":"info","ts":1741629773.1352012,"msg":"autosaved config (load with --resume flag)","file":"/config/caddy/autosave.json"}
{"level":"info","ts":1741629773.1352048,"msg":"serving initial configuration"}
{"level":"info","ts":1741629773.1355035,"logger":"tls","msg":"storage cleaning happened too recently; skipping for now","storage":"FileStorage:/data/caddy","instance":"90cb01b0-ac44-49fa-9431-425e82e233e5","try_again":1741716173.1355026,"try_again_in":86399.999999822}
{"level":"info","ts":1741629773.1355288,"logger":"tls","msg":"finished cleaning storage units"}
iarekylew00t/caddy-cloudflare:latest
Unraid 6.12.4
docker run
  -d
  --name='caddy'
  --net='bridge'
  -e TZ="America/Los_Angeles"
  -e HOST_OS="Unraid"
  -e HOST_HOSTNAME="Tower"
  -e HOST_CONTAINERNAME="caddy"
  -l net.unraid.docker.managed=dockerman
  -l net.unraid.docker.icon='https://hub.docker.com/api/media/repos_logo/v1/library%2Fcaddy'
  -p '1443:443/tcp'
  -p '180:80/tcp'
  -p '1443:443/udp' 'iarekylew00t/caddy-cloudflare'
1623917a6856ee76733959c568abc694fea20c83fd4b11615a90ad450431a64d
https://jellyfin.nagpal.house {
        reverse_proxy 10.0.0.141
                dns cloudflare REDACTED API KEY
What exactly is the misconfiguration you believe you’re having? Is it due to not having HTTPS with Jellyfin? If so, it’s because of this error:
It appears you may have some kind of misconfiguration, which is likely the ports. No idea why you aren’t using the default ports, but you’ll need to add this to your global options block.
	http_port 180
	https_port 1443
That log message means the shared config isn’t the same as the one applied and given to Caddy.
@tknx please share proper details. We cannot help on hypotheticals.
