Basic Caddy Upgrade Docker with cloudflare
V2 :latest (there’s no caddy:2.0.0 amd64 image btw)
docker compose.ymp
    image: caddy:latest
    restart: always
      - ACME_AGREE=true
      - CLOUDFLARE_EMAIL=cloudflare email
      - CLOUDFLARE_API_KEY=cloudflare key
      - caddy-proxy
      - 80:80
      - 8480:8480
      - 8443:8443
    secrets:
      - cloudflare_api
      - cloudflare_email
    dns:
      - 192.168.10.1
      - ./caddy/certs:/root/.caddy
      - ./caddy/srv:/srv
Ubuntu 19.04 LTS
n//a?
paste full file contents here
(tls) {
        tls letsencrypt@domain.com {
                dns cloudflare
                wildcard
USG
https://unifi.internal.domain.com {
        import tls
        log / stdout "Unifi          : {common}"
        errors stdout
        #not working
        reverse_proxy / https://192.168.10.45:8444/ {
                insecure_skip_verify
        websocket
Figuring out how to start.
Apart from changing proxy to reverse_proxy in the caddy file and pulling the new image, I’m kinda stuck.
I used to use teh abisoft caddy image for v1, which may have had the cloudflare plugin added? So first step, how to I add that? Do i ned to build each time?
Then as I’ll be using a new machine with a branch of my caddy file, how can I test the certs are being pulled down ( moving the the acme test api end point, the docs said I could do it, but didn’t show me how).
We’re working on it! Something seemed to have gone wrong when we triggered the docker builds.
I think you’re looking for the builder image, you’ll need to install the GitHub - caddy-dns/cloudflare: Caddy module: dns.providers.cloudflare plugin. See the docs on docker hub, specifically the “Adding custom Caddy modules” section.
So does that mean I have to create my own dockerfle and use that? Which extends the base official docker image?
Unless I can do it somehow in a compose file.
Yep! It might look like this:
FROM caddy:2.0.0-builder AS builder
RUN caddy-builder \
    github.com/caddy-dns/cloudflare
FROM caddy:2.0.0
Mnaged to get over that. So adding a Dockerfile as per you example then the following in the compose:
    build:
      dockerfile: ${PWD}/caddy/Dockerfile
      context: ${PWD}/caddy
I ned to verify if the ${PWD} does anything, I cheated and put the full path. But this built the image an dused it with the cloudflare plugin.
So next step is understanding how to use it.
Current caddyfile has a tls section which told it my meail address and how to pull from cloudflare.
But now it seems to waht a special challenge field. But it doesn’t quite tell me where it should go:
	"challenges": {
		"dns": {
			"provider": "cloudflare",
			"api_token": "secret"
Source: Caddy2 cloudflare plugin - #3 by Dejan_Milosevic but all the links are bad.
You can just do this:
      dockerfile: ./caddy/Dockerfile
      context: ./caddy
Relative paths from the docker-compose.yml
In the Caddyfile it would look like this:
        dns cloudflare <api_token>
And just FYI the JSON docs on the website – for that field in particular – are outdated until about an hour from now. They were one of the last things to change.
Edit: They’re current now.
Cool that got me further…and I thought I’d tried the caddy/Dockerfile, I think it needed the ./caddy removed.
Teh cloudflare thing worked. But now I see I’m up against: v2: wildcard hostnames with automatic TLS · Issue #2867 · caddyserver/caddy · GitHub As I have a wildcard cert
So reading down that issue I see th eposter has:
*.theblazehen.com {
    ask http://httpstat.us/200
  reverse_proxy / {host}.home:80
Where I have:
(tls) {
                dns cloudflare ${CLOUDFLARE_API_KEY)
                wildcard
But then on
https://unifi.domain.com {
        import tls
        errors stdout
        reverse_proxy / https://192.168.10.41:8444/ {
        websocket
I import the tls entry. Or would I now go:
*.domain.com {
                wildcard
         websocket
And put them all under the *.domain.com entry?
Pleae excuse the json, I’m hoping I’ve structure it right, I write it in the post rather than in a real file to try.
    dns cloudflare {$CLOUDFLARE_API_KEY}
Reference:
I’m still updating the website docs, been a little busy today. The DNS providers were the last thing to squeeze in so they’re not really documented yet.
Any further information on how the *.domain.com and the subdomain should look?
What do you mean?
This whole post: Basic Caddy Upgrade Docker with cloudflare - #9 by psyciknz
Which uses a wildcard domain name and then a subdomain
I still don’t understand your question.
To get a wildcard cert, just use a wildcard in your site address, like: *.example.com and then enable the DNS challenge for that site.
So my question is how should the json look for that.
All the posts i’ve seen and or docs don’t really present a single json to apply those two directives. In that post I presented a possible json down the bottom (which I’ve subsequenty found does not work).
So my question is, what does the entire section look like.
This Caddyfile will get you a wildcard cert:
*.example.com
Assuming you use Cloudflare and your API token is in that env variable.
How do I reference that wildcard (tls) for a subdomain?
In caddy v1, I’d create an entry:
unifi.domain.com {
import tls
ie import the tls entry, which is named in your wildcard example.
Is that still current?
