1. Caddy version (2.1.1
Windows 10 64 bit
caddy_windows_amd64.exe run --config caddy.json
N/A
"apps": {
"http": {
"servers": {
"srv0": {
"listen": [
":444"
"routes": [
"match": [
"host": [
"localhost"
"handle": [
"handler": "subroute",
"routes": [
"handle": [
"handler": "vars",
"root": "C:\\Caddy\\srv"
"handle": [
"handler": "authentication",
"providers": {
"http_basic": {
"accounts": [
"password": "JDJhJDEwJEVCNmdaNEg2Ti5iejRMYkF3MFZhZ3VtV3E1SzBWZEZ5Q3VWc0tzOEJwZE9TaFlZdEVkZDhX",
"username": "Bob"
"hash": {
"algorithm": "bcrypt"
"hash_cache": {}
"match": [
"path": [
"/restricted/*"
"handle": [
"browse": {},
"handler": "file_server"
"terminal": true
"errors": {
"routes": [
"match": [
"host": [
"localhost"
"handle": [
"routes": [
"handle": [
"body": "404 Not Found",
"handler": "static_response"
"match": [
"expression": "{http.error.status_code} == 404"
"terminal": true
When I add error handling to my configuration file (to return text and add HSTS headers) it breaks basic authentication. To replicate the issue run this configuration file and browse to https://localhost:444/restricted/, a blank white page will be displayed. Looking in the browsers network requests or using curl shows HTTP 200 along with www-authenticate.
< HTTP/2 200
< alt-svc: h3-29=":443"; ma=2592000
< server: Caddy
< www-authenticate: Basic realm="restricted"
< content-length: 0
< date: Wed, 26 Aug 2020 01:56:18 GMT
If you remove the error handler everything functions normally.
I don’t have any error logs. I tried turning on logging but was only able to log the full request. Whatever is going on seems to be normal, at least to Caddy.
I reformatting the error handling several times (but unfortunately didn’t save it). I attempted to make the authentication handler send HTTP 401 manually, but it only ever sent 200 (I figured it would be a long shot).
I made this simpler configuration file that still replicates the issue to try and eliminate variables.
